Personalizing a 350Z?
Old Sep 26, 2018 | 07:47 AM
  #41
Zet3's Avatar
Zet3
Thanks.
I saw the duraflex one on ebay. I didn't considered it because of duraflex bad rep and because they were not really what I was looking for.
About the ings, I would like to try to find something which is more well integrated into the body of the car.
By the way, are these little add ons after the front wheel stock or aftermarket?
I also saw cars which had them at the rear as well, in front of the rear wheels. But now I can't find any photos.
Old Sep 26, 2018 | 09:23 AM
  #42
Heel Til I Die's Avatar
Heel Til I Die
The part that you circled is an OEM part. It's a mud guard or mudflap. There's one behind the rear wheel in your picture as well.
It sounds like you're describing the Veilside V1 "underwings."
Old Sep 26, 2018 | 10:23 AM
  #43
Zet3's Avatar
Zet3
Thanks. So they are mudflaps? And here I was thinking they served some aerodynamic purpose.
But what I was talking about was not the underwings. It was basically like the front mudflap in my picture. But it was in front of the rear wheel. I can't find the picture. But maybe somebody just turned the front mudflaps around and glued them to the rear in front of the rear wheel. I don't know. I thought they were some sort of half skirts. Or maybe there are underwings which look very similar to the OEM mudflap.
And do the underwings serve any real aero purposes?
Old Sep 27, 2018 | 04:19 AM
  #44
MicVelo's Avatar
350Z/370Z Tech Moderator
Very few body wing/spoiler/lip/sideskirt add-on "aero" is actually aero. There are many components and tweaks that need to be added to them to make them effective or even take away the extra aerodynamic drag that they're actually adding. Got a wind tunnel?
Nissan apparently does (or uses someone's); the Nismo 33 and 34 bodywork actually DOES work. The dinner tray double rear wing and rear fascia work together to slip air over and under the car to produce something like 30+ lbs of rear downforce (versus the stock Z producing nearly 20lbs LIFT....) Combine lift with a bunch of untested FRP or poly add ons producing drag..... ehhh.
But none of that really matters at road speeds other than a possible half a mile less per gallon so just enjoy the "aero body" for what it is, a styling statement.
So you're sure what you saw wasn't the Veilside (or "VS rep" as they're called by everybody who makes them)?
Oddly, these are one of the only "aero" add ons I like. Matter of fact, as I've mentioned (and shown in another thread about my CF rear "Track version" lip), I have (or actually sold off) several add on body pieces that I purchased but just couldn't get myself to install because of a number of reasons: fear of messing up the car's style lines, ruining the aero, paint mismatch, etc.
In coming weeks, going to put it all on - in temporary fashion - for evaluation purposes. F, R, sides for kicks.
This is a member's car that totally inspired me to buy the pieces! (sry110-holler if you want me to take the pic down) This is a MicTopTen car due to its subtlety and well executed body/stance.
Old Sep 27, 2018 | 05:38 AM
  #45
Heel Til I Die
Similar to the Veilside sides are the Chargespeed side cowls. They "flare" out a little more at the rears than the Veilside which look to be flush with the body.
Old Sep 27, 2018 | 07:51 AM
  #46
Zet3's Avatar
Zet3
I could swear that what I saw was more like this:
This is photoshoped by the way. But it really looked like just another mudflap in front of the rear wheel. It didn't look at all like these more flush underwings. But now I can't find the picture anymore. I could of course be mistaking. But I have the impression I saw the above or very close to it.
Old Sep 27, 2018 | 07:54 AM
  #47
Zet3's Avatar
Zet3
Hmm, I supposed these could be what I might have seen. Maybe from a different angle it would look close enough to confused me. The only thing is that they were short like the OEM mudflaps instead of extending so much away from the wheel like both these types of underings do. So I'm still thinking this was not it.
Old Sep 27, 2018 | 08:12 AM
  #48
MicVelo's Avatar
Well, maybe that owner just wanted to keep mud and rubber off his doors during bitchin’ reverse burnouts.
That stuff is hard to remove.
Old Sep 27, 2018 | 09:20 AM
  #49
Heel Til I Die
I heard that if you drive a '61 Ferrari 250GT in reverse, the miles will go down.
Just be sure to not kick the front bumper in a fit of teenage angsty rage.
Sorry... couldn't help myself. Throwback Thursday!
Old Sep 27, 2018 | 12:12 PM
  #50
MicVelo's Avatar
"I am not going to sit on my *** as the events that affect me unfold to determine the course of my life. I'm going to take a stand. I'm going to defend it. Right or wrong, I'm going to defend it."
Old Sep 27, 2018 | 03:20 PM
  #51
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
my car is basically back in stock form, I like it that way.
Old Sep 27, 2018 | 10:05 PM
  #52
Zet3's Avatar
Zet3
In my exhaustive search for body kits I found this photo:
It came up with the search 350Z side skirts. Anybody knows which kit is that? This would be perfect. Thanks.
Old Sep 28, 2018 | 04:03 PM
  #53
Heel Til I Die
To me, that doesn't look like a 350z door since it doesn't taper at the bottom. Are you sure those sides are for a Z33?
Old Sep 28, 2018 | 04:31 PM
  #54
MicVelo's Avatar
NOT a Z door.
Old Oct 1, 2018 | 11:59 PM
  #55
Zet3's Avatar
Zet3
Yes, I see the difference now.
By the way, I'm still going through google images using different combinations of search words and the amount of body kits made for the 350Z is unbelievable! I've been at it for days now during my spare time and I still manage to find new kits I haven't seen. Most of them are ugly or excessive for my tastes. Others seem to try to make the car look like a Porsche or something, which I also don't like. Very few are of good taste for me. But the sheer number of kits available are just crazy. It seems to have no end. Has anybody ever collected all the existing kits in one place or site?
I guess this shows how popular the car is or was. But here you never see one at all. I guess in the U.S. they are common sight? I know that in the UK they are on the rare side too. Not sure Japan.
Old Oct 2, 2018 | 05:10 AM
  #56
Heel Til I Die
This site has a lot of them. Not all - but most of the different styles. You just enter the year, make, model: https://www.bodykits.com/c-1234250-b...body-kits.html
Old Oct 2, 2018 | 01:52 PM
  #57
Zet3's Avatar
Zet3
Thanks for the link. I had seen that site. It has a lot of repeated kits with different names it seems. Actually this is a recurring theme while searching. The same kits with different names. I guess copies of copies etc. So far I haven't found a kit I like. Some separated parts which could be usable. But no nose I like yet for example. But the kits are either too much or too little. Nothing that makes the car look more classy and more classic or special. It either doesn't do much or goes full on clown shoe. But I'm still looking.
Old Oct 2, 2018 | 04:03 PM
  #58
MicVelo's Avatar
There's always this good old standby....
You did say "rounded" at one point.... this is kinda rounded.
"Bond, James Bond."
Old Oct 3, 2018 | 12:08 AM
  #59
Zet3's Avatar
Zet3
Yes, I saw that.
But you know what? If it wasn't for the Aston shaped grill, it's not a bad looking bumper or look. Understated and classy, besides trying to be an Aston. If the grill opening was more circular or less Aston I think it would be a nice look. The problem is trying to pass as something which it isn't. It's the same case with the GT-R bumpers for the 350Z. Kitschy. This particular photo above is very bad though. I saw pictures of people's actual cars with that bumper and it looks better. The problem is the Aston grill. But Aston grill or not, it still looks better than a lot of body kits out there. I would rather have the above Aston bumper than excessive or ricer stuff such as these:
There are a lot more. But I think I made the point.
And don't even get me started on Lambo doors.
There is also the Rocket Bunny stuff which is way too much for the street. I don't even know why people do it to things like Ferraris and Maseratis.
There are also other kits which seem to try to make the car look like a Porsche:
A ricer "Porsche":
To me this is almost as bad as the Aston bumper. It's not as obvious put pretty clear where the influence comes from.
The 350Z has already enough 911 and Audi TT for my liking. I would rather distance the car from that than bring it closer if I'm to modify it.
Talking about the TT, fat round tackled on wheel arches on the 350Z make it look like a gen 1 Audi TT. The rear is already very round and TT like.
Besides the above Porsche-like kits also look a bit ricer in my opinion. The Stillen (metallic orange one in the middle) is only the skirts that are ricer. The bumper could be OEM. But too Porsche.
Anything which has a solid low racing lip almost scrapping the ground on a street car is too much for me. There is a reason Aston doesn't do it in their normal cars. Neither does Mercedes, Porsche, Jaguar, Maserati, Ferrari, Alfa Romeo etc. It looks cheap, kitschy and tasteless on a street car. When they need the lower lip, for real aerodynamics, they try to understate it as much as they can and keep it classy. So a solid, mono plastic piece scrapping the ground is not my taste. Nothing screams ricer more than a single piece bumper full of wings and holes with a low fat hanging lip. This is the main problem in finding something I like. There are some nice looking bumpers. But the low rent look of the extra low and thick lip scrapping the ground turns me off.
Old Oct 4, 2018 | 12:32 PM
  #60
Zet3's Avatar
Zet3
Good news. Finally found side skirts that I like. And this one is definitely a 350Z.
I wish they were a little more seamless at the top and blended into the body a bit better. But maybe this can be done by a good body shop? Is it a matter of just sanding it down a bit? If they can be made to fit smoothly with the body without the thick seam, I think this will be as close as I can get to what I want.
