Broken A/C line cant find correct part
Old May 11, 2019 | 09:10 AM
Josh Gerena's Avatar
Josh Gerena
Default Broken A/C line cant find correct part
So my usual shop told me my KN rubbed through my high pressure A/C discharge line. They wanted 400 for the part I said no and now they wont show me which line it is so I need help. What I know is that its the line that runs from the compressor to the condenser and it is high pressure "A/C Discharge". Could someone help me find the part num? This is an 04 350Z
Old May 11, 2019 | 09:51 AM
i8acobra's Avatar
i8acobra
Go to Rockauto.com...
Four Seasons Part #55021
EDIT: https://www.rockauto.com/en/parts/fo...rant+hose,6900
Old May 11, 2019 | 04:13 PM
Evenflow80's Avatar
Evenflow80
If you mean the heat shield on the K&N air intake rubbing through that white pipe under it I feel it's already doing the same to mine. How can you prevent that ?
Old May 11, 2019 | 08:14 PM
Josh Gerena
Yeah it took 2 years for mine to fully break so you might have some time. Maybe instead of deleting heat shield you could put heat covers on the pipes underneath kinda like a turbo.
Old May 12, 2019 | 05:03 AM
travlee's Avatar
travlee
Master
get a piece of exhaust hanger rubber, like below, and zip tie it to the line
Old May 12, 2019 | 06:12 AM
Evenflow80's Avatar
Evenflow80
Thanks man I'll go to AutoZone today hope they have it
Old May 13, 2019 | 07:08 AM
OldManZFL's Avatar
OldManZFL
to assist with install, this is a very common issue with aftermarket intakes
R350Zz33
May 27, 2010 10:38 AM
enlite
Mar 27, 2009 08:42 AM
