Rear camber
Old Jul 5, 2019 | 06:33 PM
Chuck Odum's Avatar
Chuck Odum
Default Rear camber
Every time I type in "rear camber adjustment" for the 350, all I get is rear camber kits. The camber, unless I am badly mistake, IS adjustable with the factory parts. Maybe not if you want 45 degrees of negative, but that is not what I am looking for. I just want to even out tire wear across the tire and I have also noticed, that the other tire is perfect. I also noticed that the good tire was farther out at the top, judging from the rear fender than the other. So more positive camber on the good tire. Why no info on factory adjustment? (and I know everyone is trying to sell something). But take a look at the factory eccentric camber washer and there is a lot of adjustment. I have already made an adjustment, but would like to hear some opinions. Thanks, Chuck
Old Jul 5, 2019 | 09:47 PM
terrasmak's Avatar
Many factors, most of the time at stick height you can get back into OEM specs.
Then the range of spec is close to a full degree, some wrench monkeys will just get it in the green and call it good, you can have a degree difference between sides and technically good.
Fixxxercask
Suspension
Feb 19, 2015 11:30 AM
dkmesa350z
Suspension
Jan 14, 2015 03:43 PM
procustomize
Suspension
17
Mar 15, 2013 06:33 AM
aj217
Jan 18, 2013 03:36 AM
