GTR R35 coils on an HR 350Z
Old 10-10-2020, 10:56 AM
Bmsluite
Bmsluite's Avatar
Default GTR R35 coils on an HR 350Z
Well it seems the new Hitachi coils I got for my 350Z are now also going out. Had a low rpm stutter. Fixed it will new coils. Now stuttering AGAIN. Annoying af.
Hearing the GTR coils have a stronger spark. Cna I just swap the boot over and it's plug and play? Did some research but didn't find too much. Anybody done this swap?
Old 10-10-2020, 12:52 PM
travlee
Master
travlee's Avatar
Received 9,127 Likes on 6,580 Posts
Have you tested the coils?
Not saying this is the case, but maybe it was just coincidence that it cleared up when you swapped them, maybe the plug or wiring. Just throwing things out there
Old 10-10-2020, 01:36 PM
DarkZ03
DarkZ03's Avatar
98% of spark related concerns outside of a wiring issue will be subdued with new ignition components. Most likely a bandaid, the question is if it's the sparks fault or an outside issue that the new components masked...is the problem constant?
Old 10-10-2020, 01:43 PM
Bmsluite
Bmsluite's Avatar
Intermittent. Happens much more when the engine is very hot and then I'm in city traffic. I've had this same problem with multiple cars in the past. Coils always fixed it. I've never had it come back though.
I cleaned up the ground points on the engine and the ground points where it connects to the chassis thinking maybe a bad ground could have fried them. I did that before I even swapped the coils.
It's also possible I just got one bad coil. Do you guys know what kind of resistance I should be reading between the contacts on the coils?
Old 10-10-2020, 01:54 PM
DarkZ03
DarkZ03's Avatar
I do not, and unfortunately I can't even check mine since I have a DE, they are probably not the same.
Hayden Winborn
03-21-2017 10:20 AM
mcarther101
07-24-2013 11:58 AM
yanksfan350z
03-14-2012 03:18 PM
Shabib67
03-02-2007 11:48 AM
Quick Reply: GTR R35 coils on an HR 350Z
