Can someone help me with perfect measurement of ground clearance for 350z,
Old 12-14-2021, 04:14 AM
Sagar bhandari
Sagar bhandari's Avatar
Default Can someone help me with perfect measurement of ground clearance for 350z,
The nissan 350z 2008 is too has lower bottom, it keep hitting the hump,
You need to modify car to extend the height by finding parts outside or its extendable from car itself ? And can someone please help me with right bottom height in front and rear both side, what should be the measurement?
Old 12-14-2021, 05:10 AM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,285 Likes on 2,337 Posts
Sagar, we would need to know what type of suspension is on the car before we can say anything intelligent.
Are they standard shocks and springs or did you or someone install coilover shocks? If you don't know, take a look at your shock assemblies (best representation on Z car is to look front shocks with wheel off.)
In the pic, we know the front shocks on a Z are not the one on the left. (Won't discuss the rear right now just to avoid over complicating.) The one in the middle is what you'd see on a stock Z. The one on the right is a coilover shock with the primary VISIBLE difference is the threading and adjustable collar on the outside of the shock body.
Generic pic, not a Z.
If you are having a hard time with this, take a pic and post it.
Old 12-14-2021, 06:44 AM
iideadeyeii
iideadeyeii's Avatar
The ground clearance of a stock z should be ~4.75" from what google says. I'd go off around that height
Old 12-14-2021, 09:07 AM
JCat
JCat's Avatar
The following 2 users liked this post by JCat:
SonnyWu (12-16-2021), WYZIWYG (12-14-2021)
Old 12-21-2021, 10:37 AM
Sagar bhandari
Old 12-21-2021, 11:04 AM
travlee
Master
travlee's Avatar
Received 9,126 Likes on 6,579 Posts
tein springs, not sure if they are s-tech or h-tech
jhc (12-21-2021)
Nismo tuned 350
06-27-2008 09:45 AM
Sqwadldr
06-21-2008 08:38 AM
Quick Reply: Can someone help me with perfect measurement of ground clearance for 350z,
