Nissan 350z 2004 Radiator
Old Sep 13, 2022 | 03:39 AM
wcharon's Avatar
wcharon
Default Nissan 350z 2004 Radiator
Hi to all...
Need some advice on my Radiator that cracked on the upper fiberglass part . Was checking around and i see Mashimoto and others have aluminum replaces.
It is worth to go aftermarket if i don't track the car as they state they are bigger? Also mine is a DE motor so it need to have the integrated, internal transmission cooler as it is automatic.
Appreciate your feedback and thanks in advance.
Old Sep 13, 2022 | 05:15 AM
iideadeyeii's Avatar
iideadeyeii
Go stock replacement.
Old Sep 13, 2022 | 06:33 AM
lifekenophobic's Avatar
lifekenophobic
As deadeye said, just go with an OEM radiator. I don't know of an aftermarket radiator that has a built-in trans cooler, so you would most likely need an external trans cooler for any aftermarket radiator. Mishimoto and Koyorad for sure don't have built-in transmission coolers.
My Mishimoto also fit like garbage, so I wouldn't recommend them anyway for a radiator.
Old Sep 13, 2022 | 10:34 AM
wcharon's Avatar
wcharon
Thanks for the suggestion. I called Nissan and they don't have it in stock and the wait time is 1 month. In top of that the price went up to $500.00.
Decided to go aftermarket and they stated that it have the internal cooler as that was my main concern also and the Radiator have Lifetime Warranty which is a plus. They had it in stock so will be installing on Thursday and let you guys know how it works.
Thanks once again.
Harbison
Oct 17, 2018 10:22 AM
speedk1ng
Cooling System
17
Mar 14, 2014 09:13 AM
mw9
Dec 1, 2010 02:31 AM
HEUGE
Sep 26, 2004 07:08 PM
