2003 Starting issue
Old Dec 16, 2022 | 08:49 PM
Gutlesstoast's Avatar
Gutlesstoast
Default 2003 Starting issue
Im having a problem with my 2003 140k miles it will start fine cold or warm but after a drive will crank ALOT longer while warm. I replaced the fuel pump today but still having the issue.
Any help?
Old Dec 17, 2022 | 01:50 AM
travlee's Avatar
travlee
Master
Cam shaft sensors
Old Dec 17, 2022 | 11:45 AM
Gutlesstoast
Originally Posted by travlee
Cam shaft sensors
I actually seen you comment that on another similar thread, so in my case. No CEL it will start perfectly fine and run cold and warm but after a drive it has a hard time starting. Doesn't die at idle or struggle to idle either.
thanks for the reply!
Old Dec 17, 2022 | 12:33 PM
travlee's Avatar
travlee
Master
They don't always throw a CEL. A buddy had exact same issues as you, know what it was???
Camshaft sensors
Old Jan 2, 2023 | 08:01 PM
Gutlesstoast
Camshaft sensors
Thanks so much man replaced crank and camshaft sensors with brand new Hitachi ones and the problem was solved!
Klineb199
Sep 29, 2021 04:56 PM
bubbatire
Apr 27, 2018 09:21 AM
bdub05
May 3, 2016 06:03 PM
DEMoLITIoN
Apr 8, 2013 08:23 AM
