19 Inch G35 Wheel Specs?
Old Oct 26, 2023 | 07:21 PM
Tech Territory's Avatar
Tech Territory
Default 19 Inch G35 Wheel Specs?
Hello! I have a 2003 Nissan 350z, and I just recently bought a set of 19 inch G35 wheels to put on the car, but im wondering what tires I should put on the car? I really dont like the look of a stretched tire, and want the more flush with the lip look, where you cant see the tip of the wheel lip, and I have also heard that the 19 inch g35 wheels are staggered, so i wasnt sure, the current tires on the car were run on a stance car, and every single one of them is a different brand/tire, and one of them is a 40 aspect ratio while all the others are 35, so i need to replace them, but wondering what mm thickness I should get? Any help is appreciated thanks!
Old Oct 27, 2023 | 06:22 AM
Heel Til I Die's Avatar
Heel Til I Die
I think the OEM sizes on the staggered G35 Rays wheels would be 225/40/19 and 245/40/19. If you're going wider, just stay within a 3% rotational difference to avoid problems with VDC/TCS (if you have it).
Old Oct 27, 2023 | 08:22 AM
Tech Territory
ah okay thanks!
Old Oct 27, 2023 | 08:54 AM
Heel Til I Die
There's no telling what size wheels you have based on the tire sizes since people are dumb. Sounds like the previous owner was especially dumb since they were running 3 tires on a 35 and one 40. The specs should be stamped on the inside of the spokes. They should be 19x8 and 19x8.5 with a +30/33 offset.
Old Oct 27, 2023 | 08:58 AM
Tech Territory
ah okay thanks! So whats the thickness of the wheels?? 9, and 9.5? or what?
Old Oct 27, 2023 | 03:38 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
You are tire limited by the wheel size, 8F/8.5R.
225/40 front and 245/40 rear are your best fit balancing the wheel width limitation with stagger requirement.
Ideal tire on 19s is 245/35 & 275/35 but the OE G35 wheels aren't wide enough to support those sizes.
Old Oct 30, 2023 | 10:00 AM
Tech Territory
i bought 225/35r19, and 245/35r19... will those fit nice?
Old Oct 31, 2023 | 06:56 PM
MicVelo's Avatar
i bought 225/30r19, and 245/35r19... will those fit nice?
Feel like I just answered a similar questiion earlier...
​​​​​​​Stock 18s
225/45-18 F 25.97"
245/45-18 R 26.68"
Your tires
F: 225/30-19 F 24.31"
R: 245/35-19 R 25.75"
So yeah, sorry, but lame sizing. I already gave you optimal sizing for narrow wheels.
People, please pay attention to overall rolling diameters.
1. Section width/25.4 (converting to inches or if you're in the metric world, skip this.)
2. (Section width x aspect ratio in percentages, e.g. ".35", ".40") x 2 (two side wall​​​​​​​s)
3. + wheel diameter
4. = overall diameter
Not rocket science.
Old Nov 1, 2023 | 04:40 AM
Heel Til I Die
Not rocket science.
Old Nov 1, 2023 | 06:44 AM
MicVelo's Avatar
Oh, Wollowitz, you dawg.
Old Nov 2, 2023 | 03:20 PM
Tech Territory
​​​​​​​Stock 18s
225/45-18 F 25.97"
245/45-18 R 26.68"
Your tires
3. + wheel diameter
Not rocket science.
But i have the 19's......???
Old Nov 2, 2023 | 04:48 PM
MicVelo's Avatar
Comparing stock 18" diameters to your 19" diameters. Doesn't matter what size the wheels are so long as you have tires of close to the same as stock diameters. Even if you had 20s, you still need to calculate the diameters to keep them close to stock (and suitable for the wheel width).
Old Nov 3, 2023 | 04:19 AM
Heel Til I Die
Bruh...
Old Nov 13, 2023 | 08:01 PM
Tech Territory
why does the diameter need to be the same? for the speedo?? cus i can just adjust that...
Old Nov 13, 2023 | 09:17 PM
MicVelo's Avatar
You wanna put those short tires on and adjust out the wheel gap and speed differences, just do it. I'm done.
Old Nov 14, 2023 | 02:01 AM
travlee's Avatar
travlee
Master
maybe you should follow through with this thread
https://my350z.com/forum/2003-2009-n...-my-z-for.html
Old Nov 14, 2023 | 06:08 AM
Aeneas137's Avatar
Aeneas137
on my stock 18x8 wheels, my first tire upgrade was 255/40 rear, 245/40 front. no problem with fitment or width.
Old Nov 14, 2023 | 06:17 AM
terrasmak's Avatar
TCS/vdc is not going to be happy
Old Nov 14, 2023 | 07:21 AM
Tech Territory
its been working great for about 2 weeks!
Tech Territory
haha 🙄
