Help with Fitment and Daily Driving
Old Sep 10, 2024 | 03:50 PM
bre240z's Avatar
bre240z
I was running Ichiba spacers
Originally Posted by Someone12132
What brand spacers were you running? I like the way your stock wheels sit!
Old Sep 21, 2024 | 11:57 PM
Someone12132's Avatar
Someone12132
No name struts with no name springs making it impossible to determine the spring rate and rebound. Ditch those and go with something reputable.
I reinstalled the stock struts back on the car. I found out that it was Hotchkis lowering springs. I'm not sure what the drop amount was, but now the wheels aren't tilted inwards.
Old Sep 22, 2024 | 12:00 AM
Someone12132
I'll definitely take a look at those spacers. I'll probably look for spacers that are 15mm-20mm and of good quality.
Old Sep 23, 2024 | 04:56 AM
Heel Til I Die's Avatar
Heel Til I Die
I'm on Hotchkis springs. They have a modest drop of 15mm in the front and 19mm in the rear. The spring rate is fairly close to stock (340 lbs/in vs. OEM 310 lbs/in in the front and 330 lbs/in vs. OEM 350 lbs/in the rear). That's mainly why I chose them. When I installed them, I went with Bilstein B8 shocks/struts. I don't find the ride terribly bouncy. While you certainly can run the OEM shocks with lowering springs, you shouldn't.
I'm not a suspension expert, but I don't really see how reinstalling the OEM shocks is going to adjust the camber when you still have lowering springs on it. Unless, you reinstalled the stock springs as well. Springs affect the ride height - not struts.
Old Sep 23, 2024 | 11:02 PM
Someone12132
Sorry if I didn't make this clear, but when I referred to the struts, I am referring to both the springs and shocks combined. It's back on the stock springs now, and the camber is not as drastic anymore. The lowering springs were indeed on stock shocks, so the ride was a bit bouncy.
Old Sep 24, 2024 | 08:07 AM
Someone12132
Just out of curiosity, someone wants to sell me their Z1 15mm g37 sedan spacers. I was wondering if the stock wheels would fit these spacers and if these spacers would bolt on to the car with no issues? The hub bore size, thread pitch, and bolt pattern match those of a 350z spacer, so it should fit with no issues, right?
Old Oct 9, 2024 | 04:51 AM
WoodrowWarren's Avatar
WoodrowWarren
Nice one, I love it.
Spoiler
Old Oct 9, 2024 | 02:49 PM
Someone12132
Old Oct 9, 2024 | 05:40 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Yes.
2fastnc
Jan 11, 2011 12:42 PM
xlid007
Sep 14, 2008 09:24 PM
SDZ
Jan 9, 2006 02:01 PM
