Help!!!! Problem with ecu
Old Dec 11, 2024 | 01:17 PM
Ondjre's Avatar
Ondjre
Default Help!!!! Problem with ecu
Hey guys I did a manual swap on my z and now a throw a u1000 code for the missing auto trans. I was wondering how to fix it. I was going to get a manual ecu and see if that worked but I'm not to sure where to get one with like all the right information on it. Any thoughts/suggestions would be awsome.
Old Dec 11, 2024 | 10:51 PM
icer5160's Avatar
icer5160
You need to have your AT encoded ECU reflashed for a 6MT swap. I believe Uprev even has a feature for doing just this. Alternatively, you can try replacing the entire ECU with one from a similarly equipped (trim package) 6MT, but you will probably run into NATS issues and will need to have the new ECU encoded with matching VIN and bond with your BCM. Sadly cars are not simple plug n play items anymore.
Good Luck!
-Icer
Old Dec 12, 2024 | 07:06 AM
seymore4's Avatar
seymore4
Professional
An Uprev tune is what you need. Correct for the MT swap so the ECU isn't confused anymore and get the fuel/ timing/ throttle dialed in, your car will run 10X better plus you get some fun features like rolling anti lag, launch control, burnout mod, and map switching.
I'll PM you
Teha99
Tuning
Aug 21, 2019 05:52 AM
Paulius923
Jul 8, 2015 12:30 PM
350Zdj
Jun 15, 2014 05:26 AM
03_ppw350z
Mar 29, 2004 01:22 PM
