Rev limiter also cut air?
Old Mar 15, 2004 | 02:06 PM
Mr_Q's Avatar
Mr_Q
Default Rev limiter also cut air?
Since the Z has a "fly by wire" throttle...does it also cut air as well as fuel.
I would hope it would. Thus avoiding the nasty leaning out.
"He who often see's his rpms cut-out before he'd like"
Old Mar 15, 2004 | 02:45 PM
ZLover4Life's Avatar
ZLover4Life
just checked (for anyone who read my last resposne), 350Z does cut air and fuel as well as spark.
To never have to worry about it, just don't rev that high =/
Old Mar 15, 2004 | 02:50 PM
Mr_Q's Avatar
Mr_Q
Actually the throttle is eletrically controlled. There is no "hard" link between the gaspedal and the throttle body. It's computer controlled.
So it should be entirily possible to cut air.
Unless I am mis-informed. I was told it was a drive-by-wire throttle system. Like most newer sports cars.
Old Mar 15, 2004 | 02:51 PM
ZLover4Life
^^^^ read my revised post =D
Old Mar 15, 2004 | 02:53 PM
LiqTenExp's Avatar
LiqTenExp
If it was throttle by wire it could simply return the butterfly to a closed or lessened position. I have only test driven 3 times, im waiting to grad to buy but i know the one i test drove was a "test' mule and it had like 9k on it. I dont drive stick well since i've never owned a manual car and ill admit i tapped it a couple times. The engine though did what most cars do and hits it, backs off, and if you dont do something like shift or left of the throttle it will continue pegging the rev limiter. That means that it doesnt adjust the air flow necessarily, it doesnt feel like it lets off the throttle then gets back on it via the computer.
ok i have to edit this too, buy the time i finished other people posted.
Mr_Q's Avatar
Mr_Q
Heh, yah just saw your post update.
Here is a snip form the brochure.
"Standard features of the 350Z Roadster and Coupe include carbon-fibre composite drive shaft, traction control system, viscous limited slip rear differential, electronic drive-by-wire throttle and dual outlet exhaust. Two transmissions are available; either a close-ratio 6-speed manual or optional 5-speed automatic (with manual mode) transmission."
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
