Launching w/5AT
Old May 3, 2004 | 02:37 PM
Amnbex's Avatar
Amnbex
Default Launching w/5AT
Is there a different procedure to launch with a 5AT than with any sort of MT car? If not, should I drop from N to D or N to the Manumatic? Thanks.
Old May 3, 2004 | 03:13 PM
adrianko43's Avatar
adrianko43
No, never drop it from N to D, it will mess up ur tranny. Just step on the brake and gas at the same time. Get the revs up to around 3k (i dont have an auto so i dont know exactly how much to rev up to) then release the brake.
Old May 3, 2004 | 03:20 PM
Amnbex's Avatar
Amnbex
I thought the Z's ECU cut power to the wheels if you tried to power-brake?
Old May 3, 2004 | 03:26 PM
JonsilvZ's Avatar
JonsilvZ
Powerbrake at 1500 to get the best launch. Going higher just makes you spin. I never removed my fuse and the ECU doesnt cut the power..
Old May 3, 2004 | 04:13 PM
Amnbex's Avatar
Amnbex
TCS off unless conditions are bad, I'm assuming?
Old May 3, 2004 | 05:05 PM
BriA5's Avatar
BriA5
the ECU cuts the power when the brakes are pressed by limiting how high you can rev the engine. Try it, put the car in drive, get on the brake pedal hard, and floor it! It won't rev over about 3000 rpm. I tend to agree with JonsilvZ...anything over about 1500 will just get you spinning pretty badly.
Old May 3, 2004 | 06:11 PM
DiRN's Avatar
DiRN
You can power brake up to somewhere between 3000 and 3500 RPM. If you want to go higher than that, you'll need to disconnect the brake fuse.
bcoffee20
Nov 19, 2015 06:39 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
