Chirping the tires
Old May 7, 2004 | 04:12 PM
amairmech's Avatar
amairmech
Default Chirping the tires
Hi:
I was just wondering, Everytime i accel hard i end up chirping the tires through 2nd and 3rd, does anyone know what im doing wrong if anything and will this hurt my drivetrain. I know its rougher on the clutch but slipping the clutch a little more for the accel would wear it more, wouldnt it?
Old May 7, 2004 | 04:23 PM
___DJK___'s Avatar
___DJK___
Just let your clutch out a little more slowly. Chirping on every shift is probably not the greatest thing for your car.
Old May 7, 2004 | 04:27 PM
SlamMan's Avatar
SlamMan
Try letting off the throttle between shifts a little more. Just enough to stop the chirping. Chirping is hard on the drive train. Your right about slipping the clutch a little more, it would reduce the chirping but would wear the clutch more.
Old May 7, 2004 | 04:41 PM
mcduck's Avatar
mcduck
Hmm... is it a bad thing when you chirp your tires at 80 mph?
Old May 7, 2004 | 06:11 PM
Burrito06's Avatar
Burrito06
When I go to the track I always chrip my tires between first and second. After that it should not chirp. I agree maybe you should let off of the throttle a little bit more when you are changing gears.
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
