why is it taking nissan so long to announce 05 changes?
g35 changes were announced almost two months ago. makes me wonder if one of the changes they will announce is a feathering fix, which if announced too prematurely could greatly affect 04 sales? obviously a hp bump could do the same, but that didn't stop them from announcing the g35 changes.
Originally posted by JLC350ZX
You can bet your last dollar Nissan will not admit to a feathering fix, because that would indicate the 2003s & 2004s had a problem.
i thought that nissan had already officially acknowledged the feathering problem with that last tsb they sent out...?
You don't get my point, Nissan's TSB and extended tire warranty blame tire featuring on incorrect toe settings. If they come out with a redesigned suspension in 2005 they will not advertise it as a fix for feathering, because that would indicate the previous 350Zs had a problem.
it sounded a lot like you were saying nissan is not likely to acknowledge the feathering problem, which they already have. if you were making some other point, then i don't think anyone got it.
Yellow is the new color. Name to be determined.
The Navi's processor has been bumped to produce faster calcs.
Side view mirror surface change. All models heated mirors std.
Seat back latch (driver only).
Also, the Navi is now available only on the touring.
HP bumped to 315HP by way of induction, exaust & ECU flash.
I Had you going for a bit.
Everything stated above is per a dealers CPO Bulletin and is factual and true... EXCEPT the HP bump...
But, I hope I'm right about that!!
