Is it worth trading '03 Z for more HP in '05 Anniversary?
Guest
Posts: n/a
Horsepower 287 @ 6200 RPM (300 @ 6400 RPM on 35th Anniversary M/T and Track)
Torque (lbs/ft) 274 @ 4800 RPM (260 @ 4800 RPM on 35th Anniversary M/T and Track)
Bore & Stroke (inches/mm) 3.76" & 3.20" (95.5mm & 81.4mm)
Compression Ratio 10.3:1
Maximum Engine Speed 6600 RPM (7000 RPM on 35th Anniversary M/T and Track)
Thanks
Originally posted by gunbbang121
technosquare ecu upgrade will increase ur redline to 7100
Originally posted by shivak
The upgraded valve springs and con rods in the '05 Track/Anniversary engine will allow for an even higher redline. How does a 7500 RPM redline sound?
If the compression is the same than the 05 will be alot better to boost. And wait till you see the NA times stock with it.
Originally posted by krismax
Exactly ,now people go to 7100-7200 rpm safely with the upgraded ECU. Im sure with the new engine it will go 7500-7700 RPM safely.
It probably means that the torque curve doesn't drop off so sharply after 5.5k like it does in our cars. It's probably likes to stay in the higher range, unlike our cars where the engine craps out on you at the higher revs.
hmm for the N/a guys... +13 hp but -14 trq is just not worth it... higher redline and stronger rods mean squat in an n/a street application
I would stick with your 03 and just throw money at a TT instead of losing depreciation
Originally posted by RANDY350Z
1. Dealers will be asking at least 5000.00 +
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
