4.0l Z
Old Oct 15, 2004 | 06:27 PM
Murry's Avatar
Murry
Default 4.0l Z
I just read an article on the new pathfinder. Apparently Nissan stroked the VQ35DE to make a VQ40DE. In the pathfinder it makes 270 BHP but I'm guessing they could change cams and ECU to make more. I wonder if they have any plans to use that version in the Z. I'd like to see the stock Z have some more nads.
Old Oct 15, 2004 | 09:51 PM
axxizzer's Avatar
axxizzer
naw, we need bigger bore, not bigger stroke, the stroke is pretty long already, man
Old Oct 16, 2004 | 04:08 AM
FairladyZ's Avatar
FairladyZ
Your crazy, havent you heard of stroker motors? The LT1's have there 350's stroked to a 383, the ZO6 LS6 350 storked to a 383.
I have heard through my Z club that yes there will be a 400Z. I knew about the aniversery Z almost a year ago.
Old Oct 17, 2004 | 04:39 AM
Murry's Avatar
Murry
Originally posted by FairladyZ
Your crazy, havent you heard of stroker motors? The LT1's have there 350's stroked to a 383, the ZO6 LS6 350 stoZked to a 383.
That's what I was thinking....what's the stroke on a 383 3.75,4in,4.25in-I totally forget?
And the stroke on a 350Z is 3.2 compared to the stroke on a 400Z, which would be 3.66in. It could be done.
Old Oct 17, 2004 | 07:26 AM
7 eleven's Avatar
7 eleven
It would be pretty easy to swap the Crank to our block . You'd have to use the rods and pistons from the 4.0l due to the change in wrist pin height.
Of course you'd really want a set of forged pistions and rods. Most companys will make a set if you send them an example. It won't cost any more than an off the shelf set, just take longer to get them. In a year or two those cranks will be fairly easy and cheap to find.
If I was going to build the bottom end I'd do it that way. The only extra cost would be the crank it self.
Gary
Old Oct 19, 2004 | 10:49 PM
phoenixZ33's Avatar
phoenixZ33
The 4.0L block in the Pathfinder is considerably taller than the 3.5L block. That's not including the oil pan either.. I highly doubt it would fit.
Old Oct 20, 2004 | 05:52 AM
7 eleven's Avatar
7 eleven
What is the height vs the 3.5L?
Gary
Chadbee@Forged
Feb 23, 2012 10:21 AM
Jun
Feb 20, 2005 09:50 AM
racingdynamcs
Dec 22, 2004 06:44 AM
