programming the mirror (home link)
Old Oct 23, 2004 | 02:55 PM
doboy's Avatar
doboy
Default programming the mirror (home link)
misplaced my owners manual, and can't remember how to program my home link. Any help appreciated.
thanks
doboy
Old Oct 23, 2004 | 04:13 PM
ZtoZ's Avatar
ZtoZ
I hope this helps, copied it off my manual on CD...
Do not use the HomeLink Universal
Transceiver with any garage door
opener that lacks safety stop and
reverse features as required by federal
safety standards. (These standards
became effective for opener
models manufactured after April 1,
1982). A garage door opener which
cannot detect an object in the path of
a closing garage door and then automatically
stop and reverse, does not
meet current federal safety standards.
Using a garage door opener
without these features increases the
risk of serious injury or death.
During programming, your garage
door or gate may open or close.
Make sure that people and objects
are clear of the garage door or gate
that you are programming.
I Your vehicle's engine should be
turned off while programming the
HomeLink Universal Transceiver.
PROGRAMMING HomeLink
To program your HomeLink Transceiver to operate
a garage door, gate, or entry door opener,
home or office lighting, you need to be at the
same location as the device. Note: Garage door
openers (manufactured after 1996) have ªrolling
code protectionº. To program a garage door
opener equipped with ªrolling code protectionº;
you will need to use a ladder to get up to the
garage door opener motor to be able to access
the ªsmart or learnº program button.
1. To begin, press and hold the 2 outer
HomeLink buttons (to clear the memory)
until the indicator light blinks slowly (after 20
seconds). Release both buttons.
2. Position the end of the hand-held transmitter
1-3 inches away from the HomeLink surface.
SIC1856
Instruments and controls 2-37
3. Using both hands, simultaneously press and
hold both the HomeLink button you want to
program and the hand-held transmitter button.
DO NOT release the buttons until step 4 has
been completed.
4. Hold down both buttons until the indicator
light on the HomeLink flashes, changing
from a ªslow blinkº to a ªrapidly flashing blinkº.
This could take up to 90 seconds. When the
indicator light flashes rapidly, both buttons
may be released. The rapidly flashing light
indicates successful programming. To activate
the garage door or other programmed
device, press and hold the programmed
HomeLink button - releasing when the device
begins to activate.
5. If the indicator light on the HomeLink blinks
rapidly for two seconds and then turns solid,
HomeLink has picked up a ªrolling codeº
garage door opener signal. You will need to
proceed with the next steps to train the
HomeLink to complete the programming
which may require a ladder and another
person for convenience.
6. Press and release the ªsmartº or ªlearnº program
button located on the garage door
opener's motor to activate the ªtraining
modeº. This button is usually located near the
antenna wire that hangs down from the motor.
If the wire originates from under a light
lens, you will need to remove the lens to
access the program button.
NOTE: Once you have pressed and released the
program button on the garage door opener's
motor and the ªtraining lightº is lit, you
have 30 seconds in which to perform step
7. Use the help of a second person for
convenience to assist when performing
this step.
7. Quickly within 30 seconds of pressing and
releasing the garage door opener program
button, firmly press and release the
HomeLink button you've just programmed.
Press and release the HomeLink button up
to three times to complete the training.
8. Your HomeLink button should now be programmed.
(To program the remaining
HomeLink buttons for additional door or
gate openers, follow steps 2-8 only.
NOTE:
Do not repeat step one unless you want to
ªclearº all previously programmed
HomeLink buttons).
If you have any questions or are having difficulty
programming your HomeLink buttons, please
refer to the HomeLink web site at: www.
homelink.com or call 1-800-662-6200.
PROGRAMMING HomeLink FOR
CANADIAN CUSTOMERS
Prior to 1992, D.O.C. regulations required handheld
transmitters to stop transmitting after 2
seconds. To program your hand-held transmitter
to HomeLink , continue to press and hold the
HomeLink button (note steps 2 through 4
under ªProgramming HomeLink º) while you
press and re-press (ªcycleº) your hand-held
transmitter every 2 seconds until the indicator
SIC1863
2-38 Instruments and controls
light flashes rapidly (indicating successful programming).
NOTE:
If programming a garage door opener, etc.,
it is advised to unplug the device during
the ªcyclingº process to prevent possible
damage to the garage door opener components.
OPERATING THE HomeLink
UNIVERSAL TRANSCEIVER
The HomeLink Universal Transceiver (once
programmed) may now be used to activate the
garage door, etc. To operate, simply press the
appropriate programmed HomeLink Universal
Transceiver button. The red indicator light will
illuminate while the signal is being transmitted.
PROGRAMMING TROUBLE
DIAGNOSIS
If the HomeLink does not quickly learn the
hand-held transmitter information:
replace the hand-held transmitter batteries
with new batteries.
position the hand-held transmitter with its
battery area facing away from the HomeLink
surface.
press and hold both the HomeLink and
hand-held transmitter buttons without interruption.
position the hand-held transmitter 2 to 5
inches (50 to 127 mm) away from the
HomeLink surface. Hold the transmitter in
that position for up to 15 seconds. If
HomeLink is not programmed within that
time, try holding the transmitter in another
position - keeping the indicator light in view at
all times.
If you continue to have programming difficulties,
please contact the NISSAN Consumer Affairs
Department. The phone numbers are located in
the Foreword of this Owner's Manual.
CLEARING THE PROGRAMMED
INFORMATION
Individual buttons cannot be cleared, however to
clear all programming, press and hold the two
outside buttons and release when the indicator
light begins to flash (approximately 20 seconds).
REPROGRAMMING A SINGLE
HomeLink BUTTON
To reprogram a HomeLink Universal Transceiver
button, complete the following.
1. Press and hold the desired HomeLink button.
Do not release the button until step 4
has been completed.
2. When the indicator light begins to flash
slowly (after 20 seconds), position the handheld
transmitter 2 to 5 inches (50 to 127 mm)
3. Press and hold the hand-held transmitter
button.
4. The HomeLink indicator light will flash, first
slowly and then rapidly. When the indicator
light begins to flash rapidly, release both
buttons.
The HomeLink Universal Transceiver button
has now been reprogrammed. The new device
can be activated by pushing the HomeLink
button that was just programmed. This procedure
will not affect any other programmed
HomeLink buttons.
IF YOUR VEHICLE IS STOLEN
If your vehicle is stolen, you should change the
codes of any non-rolling code device that has
Instruments and controls 2-39
been programmed into HomeLink . Consult the
Owner's Manual of each device or call the
manufacturer or dealer of those devices for
additional information.
When your vehicle is recovered, you will
need to reprogram the HomeLink Universal
Transceiver with your new transmitter
information.
FCC Notice:
This device complies with FCC rules part
15. Operation is subject to the following
two conditions: (1) This device may not
cause harmful interference and (2) This
device must accept any interference that
may be received, including interference
that may cause undesired operation.
The transmitter has been tested and complies
with FCC and DOC/MDC rules.
Changes or modifications not expressly
approved by the party responsible for compliance
could void the user's authority to
operate the device.
DOC: ISTC 1763K1313
FCC I.D.: CB2V67690
2-40 Instruments and controls
Old Oct 23, 2004 | 06:57 PM
xswl0931's Avatar
xswl0931
www.homelink.com
350Z_Al
Oct 29, 2020 07:44 PM
hulkout
Apr 28, 2017 09:00 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Tochigi_236
Sep 27, 2015 03:40 PM
