Help. car dies
Old Nov 12, 2004 | 02:57 PM
gundam02's Avatar
gundam02
Default Help. car dies
Ok, so I was messing around and I took the car to 100mph and then slowed down fairly fast 100-20 in about 75-100 yds, and the engine died. So basically I was like WTF!!! So I started it back up and did the same run, it almost died again, the check engine light came on, the tach bounced but once I let go of the brake the car resumed normal operation. What is going on????
I had over 3/4 a tank of gas, so what could be causing this?? The car did feel like it was out of gas, so could the long stop be pushing the gas away from the intake in the tank? I kind of find this disturbing as this is a sports car, how can I lose power going from a straightaway to a turn??
Has this happened to anyone else? Should I take it in to Nissan??
HELP!!!!
Old Nov 12, 2004 | 04:29 PM
ragtopz's Avatar
ragtopz
do you have an intake on your car? i heard of people having stalling problems with the 6mt and intakes. i guess the oil from the filter gets all over the mas air flow meter wire.
Old Nov 13, 2004 | 02:15 PM
FLZ's Avatar
FLZ
The "fail Safe", keeps resetting. If you have an aftermarket intake, check the Oxygen Sensor. Or, Maybe try to set the rev-limiter higher.....Good luck......
Old Nov 13, 2004 | 10:29 PM
autois4pussies's Avatar
autois4pussies
by any chance were u in neutral at 100mph or while u were breaking really hard?
Old Nov 14, 2004 | 12:48 PM
2quick2fast's Avatar
2quick2fast
Also check here for some other reference...
Old Nov 14, 2004 | 05:36 PM
DBZCat's Avatar
DBZCat
wow Josh, Hope everything works out ok.
Chris350z03
Oct 8, 2023 07:19 PM
SonnyWu
Nov 24, 2015 08:19 PM
Ronso
Oct 30, 2015 12:39 PM
h8redlights
Sep 11, 2015 07:57 PM
PureR3d
Sep 10, 2015 06:23 PM
