2006 ZDayz at Tail of the Dragon Open Discussion for 2006 ZDayz at Tail of the Dragon May 19-21 Last year was huge this year I bet it will be even bigger. Event Info http://www.zdayzevents.com
car is broke at the dragon help!!
Old May 18, 2006 | 07:20 PM
BobaFettm's Avatar
BobaFettm
Default car is broke at the dragon help!!
RPM Bucking at 2500 rpm + 0 boost
okay... had a overheating issue with the trans today... made the numbers and park and **** not show up on the dash... shariff was here at zdayz thank god and was helping me out... we unplugged the ecu's hoping to reboot and maybe get it to work.. but it didnt... then sat for a long time and everything worked! trans is fine now... but now... at 2400 - 2500 rpm... and when the boost gauge is at 0 coming from negatives vaccum... up to boost... it bucks strangely... then goes into boost if pushed and looses boost hard... im guessing there is a leak in the lines somewhere... am i thinking right?
tomorrow ill probably go beg shariff for some more help! cuz im at zdayz and now cant do the dragon till the car is running decent...
Old May 19, 2006 | 07:39 AM
engiNERD350Z's Avatar
engiNERD350Z
Sorry to hear your car is down, but English owns you.
Old May 19, 2006 | 09:43 AM
pimp1911's Avatar
pimp1911
hmm
Old May 19, 2006 | 09:44 AM
BobaFettm's Avatar
BobaFettm
Shariff fixed it. Utech needed to be set to 0. THANK YOU SHARIFF!!!!
Old May 19, 2006 | 10:17 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
set to 0????
Old May 19, 2006 | 11:36 AM
TheCajunStyle's Avatar
TheCajunStyle
Yeah, don't you know about the UTEC_CAR_BROKE param?
Old May 19, 2006 | 04:56 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Your welcome...glad you are back on the road.
Old May 20, 2006 | 04:51 PM
BobaFettm's Avatar
BobaFettm
ha me too! Thanks again Sharif! Car is running fine other then the stalling from the idle being low The dragon was a blast this morning!
Old May 21, 2006 | 01:13 PM
zachcrosen's Avatar
zachcrosen
Good to hear you got the issues resolved. Brett(Tig488) told me about your problems as well. BTW, your car looked great and sounded even better!!
Old May 23, 2006 | 12:56 PM
BobaFettm's Avatar
BobaFettm
Thanks!
yah figured out why it was running so rich too... boost leak...
I drove 500 miles break in monday -> Tuesday... on Tuesday I drove it to TF... they found a oil leak where the drive shaft connects so they had to pull trans + exhaust out to seal it... Tune the car to 12.5 cuz it was getting the UTEC version 1 stutter in the rpm... so after I picked it up at 10pm... drove it to get some sleep... went to class on Wed till 9:30pm and left for ZdayZ!!!
I had no time to work out the problems
right when I pulled in my drive way from ZdayZ I found that the powersteering made a leak somehow... so i gotta fix that too lol
Old May 23, 2006 | 01:02 PM
002-M-P's Avatar
002-M-P
Thanks!
passengers side ps line got burnt through from the heat from the turbos, same thing happened to me at Fall Zdayz thing last year. Get a piece of (-6 I believe) SS hose and reroute it, works perfectly.
Old May 23, 2006 | 01:25 PM
BobaFettm's Avatar
BobaFettm
ha! Thank you so much!
etkms
Jun 19, 2022 06:30 PM
SonnyWu
Nov 24, 2015 08:19 PM
A.Font401
North East
Sep 16, 2015 01:39 PM
