2009+ 370Z General discussion and news for the Z34 (2009+) Nissan 370z with the new 3.7-liter V6
Put 370z On a Diet?
Old Nov 17, 2008 | 05:45 PM
PA 19103's Avatar
PA 19103
Default Put 370z On a Diet?
Since most of us are somewhat disappointed with the curb weight and with the hood, door panels and hatch already being aluminium, I guess carbon fiber parts is out of the window? But I am curious will there be anything any of you would do to lighten it?
Old Nov 17, 2008 | 05:47 PM
marques1's Avatar
marques1
make it a remote control car so that you can drive it outside of the car which will reduce wieght.
whoady4shoady's Avatar
whoady4shoady
Good Bye spare.
Old Nov 17, 2008 | 06:40 PM
aznguy370z's Avatar
aznguy370z
There are things that can be replaced to reduce weight but nissan has shed about 225 lbs.
the body structure was extensively revised, improving front body
torsion rigidity by 30 percent; a new front suspension cradle to reduce front body lateral bending; new rear structural reinforcements; and an underbody “V-bar” to help reduce rear lateral bending. Other enhancements include the use of a carbon fiber composite radiator housing and strengthening of the rear fender and hatch areas.
Rear body torsion rigidity is improved by up to 22 percent and rear body vertical bending rigidity is improved by up to 30 percent. The result is enhanced overall solidity and handling capability.
Since so many aspects of a sports car’s performance come down to the simple formulation of power-to-weight, the engineering teams behind the development of the new 370Z made that their priority focus. On the weight reduction side of the equation, they put the new Z® on an extremely restrictive diet. Beyond just the pounds shed with the body-in-white, every component throughout the vehicle was scrutinized. For example, fuel tank weight was reduced by 13.9 pounds, the exhaust system by 3.8 pounds, the audio system by 3.5 pounds and the 19-inch wheels by approximately seven pounds each for the fronts and six pounds for the rears – an estimated 225 pounds total.
All of these weight savings were needed, of course, to counter the added weight of the Z®’s enhanced body structure and new technology and safety features. The net weight reduction is 95 pounds for the 2009 Nissan 370Z over the comparable 350Z Enthusiast model.
Old Nov 17, 2008 | 07:29 PM
zsport1's Avatar
zsport1
I don't see what the big deal is with the weight. Most of the cars that hit the streets are going to be daily drivers so it's really not going to be that big of a deal. Unless you are going to make it into a track car I say the weight is ok where it is.
sherm
Apr 11, 2020 05:21 PM
