2009+ 370Z General discussion and news for the Z34 (2009+) Nissan 370z with the new 3.7-liter V6
Bought my 370Z.
Old Jan 9, 2009 | 08:38 AM
  #121
Xpletive's Avatar
Xpletive
Originally Posted by in.the.dark
The whole keyless thing deserves rambling of it's own, but I won't linger. It works very intuitively, but I still am reaching for a key when I go to get out.
Please go on! Seems like all manufacturers are offering some sort of keyless option now, but they all have their own implementation of it.
I'd love to hear how it's done on the 370!
Old Jan 9, 2009 | 08:53 AM
  #122
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
It's probably just like our 09 Murano. You insert the remote into a slot, then push the start button on the dash one time while holding the brake and it starts. If you only want the ignition on don't press the brake and tap the button once for radio only or twice for full ignition.
Old Jan 9, 2009 | 09:05 AM
  #123
norapat01's Avatar
norapat01
more pic of ur fiance. j/k, congrats!
Old Jan 9, 2009 | 09:17 AM
  #124
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
NICE!! How is the get up and Go compared to the 350!??!
Old Jan 9, 2009 | 09:20 AM
  #125
in.the.dark's Avatar
in.the.dark
Actually Solo, it's a completely keyless solution. You just walk up to the car, push the unlock button, get in, push start (depressing the clutch of course). You don't have to hold down the button either, just push it once. You only would need to insert the fob into the dash if the battery in the fob wasn't working, but that wouldn't likely happen for years.
Old Jan 9, 2009 | 09:26 AM
  #126
in.the.dark
Comparable . Actually, the 370Z seems a little less harsh on light throttle application. I think I read somewhere that the throttle inputs aren't linear, so you don't get a lot of bucking. The car is really smooth and composed. I do see what others have said about the engine getting harsh in the upper end. I don't know if that's the engine valves being opened more and more, or what is causing it. It doesn't seem like it's going to come apart.
Old Jan 9, 2009 | 12:09 PM
  #127
Apexi350z's Avatar
Apexi350z
Charter Member #50
So the ride is not harsh and bouncy at all? That's the one improvement I did on my 03 Z, by changing to a Tokico adj. shocks.. if that's the case, then I don't have to upgrade the shocks on the 370z..
Old Jan 9, 2009 | 12:11 PM
  #128
pony_killer's Avatar
pony_killer
Arada ninda apa
what part of htown are you in? i heard you say you were cruising off hw6 and i live in sugar land so if your ever on my side id definitly like to check it out.
Old Jan 9, 2009 | 12:46 PM
  #129
in.the.dark
Pearland
Old Jan 9, 2009 | 05:24 PM
  #130
35Z's Avatar
35Z
Default 370Z Driving Experience
I only drove the 370Z base model around the block. My driving impression is the 370Z base model has a much shorter turning radius, clutch has a smoother engagement, torque is linear compared with the stock 2003/05 350Z, and has more high end hp.
Old Jan 9, 2009 | 10:19 PM
  #131
PrimeX's Avatar
PrimeX
Pearland
OK, we need to set up a Clear Lake meet up so we can all see your car. For realz.
Old Jan 9, 2009 | 10:31 PM
  #132
JSpec350GT's Avatar
JSpec350GT
Your wife/gf is hot.
Old Jan 10, 2009 | 07:57 AM
  #133
Risky_Business's Avatar
Risky_Business
Quadrant 987c
Default LOL...
^ what this site is really about.
Old Jan 10, 2009 | 09:08 AM
  #134
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
The 350Z has a really tight turning radius....But the shorter wheelbase in the 370 will make it turn even tighter.
As for the powerband....how do you get more linear than the 350? Torque curve was flat as kansas.
Old Jan 10, 2009 | 04:28 PM
  #135
Educ8r's Avatar
Educ8r
My Red 370Z
Old Jan 12, 2009 | 07:27 AM
  #136
Vivid Racing
Vivid Racing
What's this harsh top end talk all about?? like a violent amount of TQ or... my engine was bolted together by an 8 yr old type harsh?
Old Jan 12, 2009 | 07:53 AM
  #137
in.the.dark
The sound mostly. I get a little vibration through the shifter normally, and it's about the same at high rpms.
Old Jan 12, 2009 | 08:45 AM
  #138
Vivid Racing
Vivid Racing
ohhhhhh ok no biggie then.. would be nice to know what is causing the vibration. Maybe it will be something we can look into once more people get on the road with there's.
Old Jan 14, 2009 | 07:52 AM
  #139
MDaniel22's Avatar
MDaniel22
Is the digital speedo option gone?
Old Jan 14, 2009 | 08:01 AM
  #140
in.the.dark
Yes. They have found a suitable alternative involving a round dial with numbers printed around the outer edge and a red-orange 'needle' that points to your current speed.
