Question about 350Z Wheel
Old Dec 14, 2008 | 07:38 PM
Titan13qb's Avatar
Titan13qb
Default Question about 350Z Wheel
Do the 2007/2008 Infiniti G35 Sport Wheels fit a 2003 Nissan 350Z ??? Please need to know..
Thanks
Chris Cary
Old Dec 15, 2008 | 09:09 AM
mg350ZR's Avatar
mg350ZR
Answered your question on g35driver.com, but thought I would post here as well.
The bolt pattern is the same, but the offsets are different, so the wheels will fit (assuming that you don't have brembos or other big brakes). They will be tucked in too much though, and will need spacers if you want the wheels to be flush with the fenders (or close to it).
Majority of 350Z drivers who upgrade their wheels usually step up to 19" wheels. As long as you're upgrading, why not move up to 19"s?
More info from my350Z.com FAQ section:
Q: What wheel sizes and offsets do I need?
A: Generally speaking, there are a LOT of different combinations that people are running on their Z or G.
Let's get the basics out of the way first: You need a lug pattern of 5x114.3, width between 8 and 11 inches, and diameter of 17", 18", 19", or 20".
Here are some of the more popular wheel and tire sizes (for good reason) that people put on their Z's. There is no "RIGHT" answer but there is a limit to how big or small you can go.
18" combination:
Front 18" x 8.5" , Offset +15 to +25, Tires 245/40/18
Rear 18" x 9.5" , Offset +15 to +25, Tires 275/40/18
(lower offset such as +10 in rear is possible but may require rolling)
Front 18" x 9.5" , Offset +25 to +30, Tires 255/40/18
Rear 18" x 10.5" , Offset +28 to +35, Tires 285/40/18 or 295/35/18
(lower offset such as +23 in the rear is possible but may require rolling)
19" combination:
Front 19" x 8.5" , Offset +15 to +25, Tires 245/35/19
Rear 19" x 9.5" , Offset +15 to +25, Tires 275/35/19
Front 19" x 9.5" , Offset +25 to +30, Tires 255/35/19 or 265/35/19
Rear 19" x 10.5" , Offset +23 to +32, Tires 285/35/19 or 295/35/19
(lower offset such as +23 or wider tires in the rear is possible but may require rolling)
From this, you get the idea of what is required to go with smaller wheels like 17's, (typically lighter, faster acceleration), or bigger wheels like 20's (bigger, heavier, usually makes you feel slower).
Get to know how to use the following tools and you will be able to figure out for yourself the correct offsets and tire sizes you need:
Tire size calculator (click)
Wheel Offset Calculator
Certain combinations of LOW OFFSET and/or WIDE WHEELS will require what is known as "fender rolling" or "fender cutting".
If you are not familiar with the term "fender rolling", here is a quick but useful lesson you can learn in a couple of minutes: Go outside to wherever your Z is parked. Run your fingers along the inside edge of a REAR fender just above your tires. You will feel a sharp edge and a flap of metal sticking inward towards the car. Now, go up to the FRONT fender, and feel the inside of the fender again. You should notice that the flap of metal has been "rolled" upwards on the front fenders. This is exactly what fender rolling is all about. The rear fenders will need to be rolled to make room for wide wheels or low offsets, or else your tires may rub on the metal when you take hard corners or hit bumps. Any experienced wheel/tire shop should know how to roll a fender. If you go to a shop that does not seem like they know what they're doing, get out of there.
Old Dec 15, 2008 | 12:21 PM
Titan13qb's Avatar
Titan13qb
great answer thanks very much
Old Dec 22, 2008 | 02:22 PM
Mike Wazowski's Avatar
Mike Wazowski
after reviewing the 3 threads that you have started I have come to the conclusion that you need to spend a little time reading through the forum before asking questions.
RiujinZero
Apr 16, 2021 11:31 AM
JjL
East Canada
Jun 12, 2019 03:04 AM
bcoffee20
Nov 19, 2015 06:39 PM
NYGiants0186
Sep 8, 2015 10:37 AM
