instructions on how to remove trunk paneling?
Old Dec 12, 2003 | 01:38 AM
ragtopz's Avatar
ragtopz
Default instructions on how to remove trunk paneling?
i was attempting to remove the panels in my trunk so that i could access the trunk switch. my plan is to install a trunk release button by tapping into the switch above the license plate. i removed the 2 push pins and weathersealer. i tried pulling and it didnt come off. it almost did, but something was still blocking it. anyways, i chickened out and re-installed everything.
does anybody have the cd-rom section where they discuss the removal of the roadster's panels? i would really appreciate it. or if anyone could explain it to me?
i am really nervous about messing around too much with a $38,000 car and screwing something up.
thanks in advance.
Old Dec 12, 2003 | 06:32 AM
Whataguy5431's Avatar
Whataguy5431
I've got service manual, but way it's laid out, hard to find section you need. PM me with your email and I'll send what I can.
Old Dec 12, 2003 | 06:41 AM
havabooz's Avatar
havabooz
umm...pry..and pull...no joke...it is attached by plastice "bolts" that are sons of bitches to get loose....you need to get good leverage under the piece and just keep pulling ..and once you get one part loose it will be easier to get the whole thing off
dont get scared from the sound it makes either
good luck
Old Dec 17, 2003 | 06:26 AM
spud's Avatar
spud
The plastic "bolts" are very simple to get out.
Take a ball point pen, or small screw driver to push down the center of the pin (you will hear a pop sound). That makes the plastic bolt loose and simply pull out.
To put the plastic pin back in later, that center piece of the pin you pushed in earlier, pull it up through so that it sticks above the plastic head.
Push the pin back in its hole, and push down on the center piece and you will hear it pop to lock it back in place..
Old Dec 17, 2003 | 06:01 PM
SungNamZ's Avatar
SungNamZ
Default Re: instructions on how to remove trunk paneling?
thanks in advance.
If you do a search through some of the "Bose Amp Posts" after they announced the "New" amp you will find a link which shows how to get to the amp, which will also show how to remove panels.
Old Dec 23, 2003 | 12:18 AM
ragtopz's Avatar
ragtopz
ron keller, i did a quick search and couldnt find the bose amp posts you were referring to.
i will try again this weekend. still scared though.
thanks everyone.
Old Dec 23, 2003 | 04:44 AM
havabooz's Avatar
havabooz
SPUD is talking about the front bumper plastic "bolts"..i guess he didnt realize you were talking about the trunk
like i said...pry something under and then just pull along th edges until you here a big SNAP and 5 more snaps after that
Old Dec 23, 2003 | 08:29 AM
SungNamZ's Avatar
SungNamZ
thanks everyone.
Sent you a PM, but will post here also. It can be found in "Bose Issue Resolved".
Go to: http://carstereohelp.com/stereoremo...50zBoseAmpR.htm
Old Dec 23, 2003 | 08:51 AM
SungNamZ's Avatar
SungNamZ
You go to "Bose Issue is Resolved" post and go to above site it works. Why it won't work from previous post... So try this:
http://carstereohelp.com/stereoremov...0zBoseAmpR.htm
Old Dec 29, 2003 | 10:49 PM
wakaZ's Avatar
wakaZ
Lemme know if you need help, just did my whole hatch area with Dynamat
Not too hard, had some interior removal tools. Did not break one fastener...just take your time if you do decide to go at it.
dave
Old Dec 30, 2003 | 05:53 AM
Vlad's Avatar
Vlad
What is your plan again? What do you need one more trunk release button? There is one already under the strat bar
Old Dec 30, 2003 | 07:26 PM
ragtopz's Avatar
ragtopz
vlad,
i have the roadster, so i dont have a button on the strut bar. unless, there is a button in the roadster that i am unaware of? anyways, i thought it would be cool to have a button to pop the trunk from the interior like regular cars do.
wakaZ,
thanks for the offer. i am putting this off for a bit. i want to find an oem looking button. right now i got one from radio shack.
http://www.radioshack.com/product.as...%5Fid=275-1566
it would seem a bit out of place in the z i think. i dont want it to be obvious.
i got a set of clear bumper reflectors for christmas that i would appreciate help installing though.
gary
Old Jan 2, 2004 | 05:22 AM
Vlad's Avatar
Vlad
I knew something is wrong with the roadster!
Old Jan 31, 2004 | 08:34 PM
gmartan's Avatar
gmartan
I have no idea what Nissan was thinking with this one. If the car is unlocked anyone can open the trunk from the outside and remove it's contents. I disabled that function which means that the key fob is the only resonable method for opening the trunk, providing some security. Too bad Nissan disables this function when the ignistion key is inserted.
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Depravity
Oct 1, 2015 04:49 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
