A/C with top down?
Old Jun 20, 2004 | 12:45 PM
soupnazi1's Avatar
soupnazi1
Question A/C with top down?
Just curious if roadster owners use the A/C with the top down. Eg. It's hot sunny day but you want to feel cold but have the top down.
Does this "waste" the A/C effect? (I've always used the A/C with the windows closed in my Civic to keep the cold air in.)
Old Jun 20, 2004 | 12:48 PM
Rushguy's Avatar
Rushguy
Sometimes, not much but once in awhile. Same as using the heat with the top down in cold weather but not as effective.
Old Jun 20, 2004 | 02:57 PM
elyliu's Avatar
elyliu
heater doesnt use the freon thingy tho....
I guess use it when you need it, you probably just need to refill more often....
Old Jun 20, 2004 | 07:01 PM
Ant350's Avatar
Ant350
Living in FLA I usually have the A/C on with the top down...I just make sure I set it manual; no thermostat so its always on...
I dont see that it does any harm?
Ant
Old Jun 20, 2004 | 07:26 PM
ragtopz's Avatar
ragtopz
yeah, i usually do the a/c with top down on hot days and heater with top down on cold nights.
Old Jun 20, 2004 | 07:33 PM
theSmoothDome's Avatar
theSmoothDome
when needed, the AC's on.
Old Jun 20, 2004 | 07:47 PM
jam350's Avatar
jam350
Nissan did a remarkable job of minimizing the exchange of inside and outside air in the top-down 350Z, particularly with the windows up. As a result, you can leave the automatic climate control system (ACCS) on all the time without a significant waste of fuel (required to turn the A/C compressor).
I keep my ACCS on Auto with the temperature set for ~70° year round. Rarely, I adjust the fan (rightmost ****) for more or less air flow.
Here in Denver, 40° temperature swings from one day to the next are commonplace throughout the year. My top's almost always down, but the ACCS takes the fluctuations in stride and almost always keeps me comfortable, at least with the windows up. Compensating for the greater air exchange with the windows down is a tougher challenge, but even then, the ACCS does a remarkable job.
Last winter, the same strategy kept me quite comfortable on many a 25° day wearing only a light- or medium-weight jacket -- again with the top down and the windows up.
Old Jun 21, 2004 | 02:45 PM
soupnazi1's Avatar
soupnazi1
Cool, thanks for the info guys!
Old Jun 22, 2004 | 06:34 AM
ephilyawjr's Avatar
ephilyawjr
Default A/C on always with top Down
I hardly ever drive with the A/C off. It is 95 degrees with 99% humidity in Mobile, AL. This is my second convirtible. My other one I drove for 2 years with A/C and top down, and never had a problem. - Doubt you will here.
A/C systems are sealed, so running the A/C with top down does not effect it. You only loose the CFC Free stuff if there is a leak (like a hose or something). The only problem is with all the crappy humidity in Mobile, alot of condensation builds on the vents, to the point that they actually drip.
Have fun and love your ride.
Go topless with the A/C!
Old Jun 22, 2004 | 09:53 AM
soupnazi1's Avatar
soupnazi1
Thanks ephilyawjr. I actually don't own a Z yet but can see one in my future. (3-4 years)
Old Jun 23, 2004 | 02:53 AM
Chief F1 Fan's Avatar
Chief F1 Fan
I never owned a 'vert before unless you count a soft top Wrangler! I will now ALWAYS own one after purchasing my SB roadster
norrix420
350Z Roadster
May 23, 2022 05:11 PM
roadmax
370Z Roadster
Aug 5, 2021 08:01 PM
350Z_Al
Oct 29, 2020 07:44 PM
Depravity
Oct 1, 2015 04:49 PM
