CV Joint Boot Failure
Old Apr 21, 2010 | 12:03 PM
ATX350's Avatar
ATX350
Default CV Joint Boot Failure
I only found one thread regarding CV joints after searching so wanted to document this for others to find in the future.
Somehow I managed to blow the CV joint boot. It definitely had nothing to do with 373whp, welded diff and lowering the car alot...
You can fix this by replacing the entire axle or having the existing axle repacked & rebooted. I originally wanted to replace the axle but found out that the axles are different sizes from left to right. The driver side axle is about 3 inches shorter than the passenger side. Which means the replacement axle I bought from a junkyard 350z is worthless...
Hoping others can learn from my mistake. Cheers
Old Apr 21, 2010 | 01:31 PM
ATX350's Avatar
ATX350
And, some additional reading which was helpful:
http://www.mobil.com/USA-English/Mot...placement.aspx
Over time the rubber boots of the CV joints can become cracked, torn, or otherwise compromised. Once moisture and dirt get into a CV joint and grease makes its way out, the CV joints days are numbered. Signs of impending failures are a click-click-clicking or metallic crackling noise while turning and accelerating or a clunking upon deceleration. While one can repack, reboot, and rebuild CV axles, it makes more sense for the average do-it-yourselfer to procure replacement units and swap out the old axles. If a boot is torn or missing, it is possible to save the joint if caught early enough, but usually the damage has already been done. Replacing or servicing the entire CV joint axle assembly may be the smarter move since replacing a boot may involve removing an axle, which may also involve removing half or all of the vehicle's brakes and suspension.
Old Apr 21, 2010 | 03:05 PM
SuperBlack350z's Avatar
SuperBlack350z
here are pics of Toby22's today. He's lowered a good amount. anyone know what caused this?
pr_350z
Oct 1, 2015 05:03 PM
TrackFiddy
Sep 24, 2015 09:36 AM
CrowzRSA
Sep 21, 2015 04:00 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
