hooking up review camera
unfortuneatly the 7015 does not have a wire to hook up to a reverse sensor, so the only way to do it is just plug ur camera into the video input and hit the V.SEL button on the lower left corner when u want to use it, i have this setup i bought a night vision back up cam off ebay from MANNIX and it has great resoulttion day and night
Hook up the camera power to the reverse lights, then set the HU to auto switch when the source comes on. I remember reading someone doing this setup on the Kenwood and it auto switched just fine.
that annoy to have them in reverse since you have to change the input set up on your HU. Just let the run 24/7. Kinda cool to see the view in the back when you run at high speed. Just like in the movie.
u don't have to hook it up to your reverse gear.....
Leave it on while drivin' fun stuff! It's even better when you record it and put to music//// How much did your cam cost? Thinkin of getting an IR cam for night vision..
got mine mounted dead center in my license plate.. too bad my bass from the subs make the cam die... POS! oh well only spent 50 bucks.. as far as the night mode .. if your cam is IR it automatically switches to B/W nite mode when the light dims.....I need a replacement cam that withstands high G forces... any suggestions
Tochigi_236
Sep 27, 2015 03:40 PM
