antenna pwr booster wiring
Old Jun 29, 2005 | 09:00 AM
VO...'s Avatar
VO...
Administrator
Default antenna pwr booster wiring
Got a question follow Z owners. I have a 2003 Touring model. All Bose equipment has been removed, including the Bose amp. Current HU is a Pioneer AVH-(can't remeber the #'s), but it's a flip in-dash touch screen. I need to power up the antenna booster with the HU's antenna remote wire. I know that the Antenna booster color code (@ the factory radio harness) is green/white. What I need to know is, is it the same color at the actual booster itself? Also, is the booster in the trunk next to the factory amp location? I need to know because I am currently using a Bosch relay to energize 2 amps and power 2 cooling fans. The relay, amps, & fans are in the cubby hole behind my driver seat. I will have to splice in a new wire to the relay, so I can power the antenna booster. Thanx guys.
Old Jun 29, 2005 | 02:49 PM
VO...'s Avatar
VO...
Administrator
Never mind. Found the answer in a past thread. The "search" option is great.
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
