What SUb should I get???
I will be doing my install soon. But I am stuck deciding if I should go with JL Audio 12W6V2 rated at 400 watts or do I go with the 10W7 rated at 500 watts. I will be powering it with JL Audio 500/1 amp. Any advice. And will I have enough volume if I fit the subs into the spare tire well using a custom install??? Thanks
12W6v2. Better performance in lowest end range.
Makes a big difference though for what kinda music u listen to. For me, I'd actually do a 10W6v2 - better reaction speed for rock music, etc.
That amp by the way is bitchin. I got my gf a 250/1 with a 12W3 setup, and even that small system can spread the bass around a parking lot. . . Needs Dynamat though (toy camry).
Good luck. In terms of volume, I think someone here's done the tire well fiberglass water trick. . . Or you can just measure and get a rough estimate.
