Wireing TFT Farenheit LCD
Old Sep 15, 2005 | 08:19 AM
solodesignz's Avatar
solodesignz
Default Wireing TFT Farenheit LCD
Hey,
I am trying to find out the best way to power my LCD screen. What type of wire and what type of fuse to run from the battery? Or should the power come from some other source, not straight from the battery?
Thanks alot
Old Sep 15, 2005 | 02:47 PM
jtekk's Avatar
jtekk
the power dont really have to come from the battery... when i had my lcd screen installed on my previous car, i just wired it straight to the fuse box for power on.... Used the "ACC On" so tv will be powered when i put the key in the ignition...
Old Sep 15, 2005 | 03:00 PM
THEDUKE's Avatar
THEDUKE
Grab all your wires at the head unit wires. Everything you need should be there. Ground, Acc, and constant. Plus they are also fused at the fuse box.
Old Sep 18, 2005 | 09:12 AM
Shift_Daytona Z's Avatar
Shift_Daytona Z
Just make sure that whatever circuit that you cut into, you are not overloading it. The radio circuit should be fine if you have nothing else hooked into it
Old Sep 19, 2005 | 09:17 AM
solodesignz
Thanks.. ran from the HU.. works great
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
