Alarm/Remote start/ install wiring colors and locations
Old Sep 15, 2005 | 08:22 PM
Inovashn's Avatar
Inovashn
Default Alarm/Remote start/ install wiring colors and locations
Sticky this if you want. Straight from DEI
Inovashn's Avatar
Inovashn
03 350Z
DIRECTWIRE™ WIRING INFORMATION - NISSAN / 350Z / 2003 / Remote Start
12volts white/blue + ignition harness
Starter white/red + ignition harness
Second Starter white/green + ignition harness
Ignition black/red + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory white/black + ignition harness
Second Accessory N/A
Keysense black/red + ignition harness
Power Lock red - driver door module in door
Notes: These are the driver door key cylinder wires. Meter the wires while turning the key in the driver door.
Power Unlock lt. blue (double pulse) - driver door module in door
Lock Motor purple 5wi white plug, pin 30 at BCM
Notes: The BCM (Body Control Module) is in the driver kick panel below the fuse box.
Unlock Motor yellow 5wi white plug, pin 23 at BCM
Parking Lights+ red/blue + driver kick panel
Parking Lights- N/A
Hazards green/red - brown plug, pin 61 at BCM
Turn Signal(L) green/white + white plug, pin 22 at BCM
Turn Signal(R) purple/white + white plug, pin 21 at BCM
Reverse Light lt. green + driver kick panel
Door Trigger white (L), pink (R) - white plug, pin 14, 10 at BCM
Notes: Use both wires and diode isolate each.
Dome Supervision comes on with unlock
Trunk/Hatch Pin red/white - white plug, pin 18 at BCM
Hood Pin lt. green/black - hood pin switch under hood
Trunk/Hatch Release pink - brown plug, pin 76 at BCM
Notes: For hatch release can also use purple (+) in a white plug, pin 19.
The fuel door release is blue/red (-) at the switch on the dash.
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse power unlock wire
Tachometer NOT white/blue or black ac any ignition coil
Wait to start N/A
Brake Wire pink/blue + brake pedal switch
Parking Brake purple - parking brake switch
Horn Trigger green/black - steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes:
Old Sep 15, 2005 | 08:24 PM
Inovashn's Avatar
Inovashn
04 350z
DIRECTWIRE™ WIRING INFORMATION - NISSAN / 350Z / 2004 / Remote Start
Second Ignition N/A
Third Ignition N/A
Parking Lights- N/A
Wait to start N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Yes Type:
Transponder
Part #: 556UW
Notes:
Inovashn's Avatar
Inovashn
05 350z
DIRECTWIRE™ WIRING INFORMATION - NISSAN / 350Z / 2005 / Remote Start
12volts white/blue (40A) + ignition harness
Second Ignition N/A
Third Ignition N/A
Keysense black/red + ignition harness or BCM, pin 37
Power Lock red - driver door module in door, pin 6
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock lt. blue (double pulse) - driver door module in door, pin 7
Lock Motor purple 5wi BCM in driver kick, pin 50
Unlock Motor yellow 5wi BCM in driver kick, pin 44
Parking Lights+ red/blue + driver kick, harness to rear
Parking Lights- N/A
Hazards purple to green/red - switch or BCM in driver kick, pin 29
Turn Signal(L) green/white + BCM in driver kick, pin 45
Turn Signal(R) purple/white + BCM in driver kick, pin 46
Reverse Light orange or lt. green + driver kick, harness to rear
Door Trigger white (D), pink (P) - BCM in driver kick, pins 62 and 12
Dome Supervision pink - BCM in driver kick, pin 48
Trunk/Hatch Pin red - BCM in dr kick, pin 58 (CP), 57 (CV)
Trunk/Hatch Release pink - BCM in driver kick, pin 30
Notes: The trunk/hatch release motor wire is green/white to purple (+) at the BCM in the driver kick, pin 68.
Tachometer NOT white/blue, black, or red ac any ignition coil or fuel injector
Wait to start N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Yes Type:
Transponder
Part #: 556UW
Notes: Standard on all models.
Old Sep 15, 2005 | 08:27 PM
Inovashn's Avatar
Inovashn
03 G35
DIRECTWIRE™ WIRING INFORMATION - INFINITI / G35 COUPE / 2003 / Remote Start
Starter red/white or white/red + ignition harness
Second Ignition N/A
Third Ignition N/A
Keysense black/pink + ignition harness
Power Lock yellow - driver door module in door
Lock Motor purple 5wi BCM, 16 pin plug, pin 30
Notes: The BCM (Body Control Module) is in the driver kick panel, it has four white plugs and one brown plug.
Unlock Motor yellow 5wi BCM, 16 pin plug, pin 23
Parking Lights- N/A
Hazards green/red - BCM, brown plug, pin 61
Turn Signal(L) green/white + BCM, 16 pin plug, pin 22
Turn Signal(R) purple/white + BCM, 16 pin plug, pin 21
Reverse Light purple or orange + driver kick, harness to rear
Door Trigger yellow (D), pink (P) - BCM, wht 12 pin plug, pins 14 and 10
Trunk/Hatch Pin red/white - BCM, 12 pin plug, pin 18
Trunk/Hatch Release pink - BCM, brown plug, pin 76
Wait to start N/A
Parking Brake lt. green/black - parking brake switch
Horn Trigger green/black - horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Yes Type:
Transponder
Part #: 556UW
Notes:
Old Sep 15, 2005 | 08:28 PM
Inovashn's Avatar
Inovashn
04 G35
DIRECTWIRE™ WIRING INFORMATION - INFINITI / G35 COUPE / 2004 / Remote Start
Starter white/red or red/white + ignition harness
Second Ignition N/A
Third Ignition N/A
Keysense black/pink + ignition harness or BCM, pin 37
Notes: The BCM (Body Control Module) is in the driver kick panel.
Lock Motor purple 5wi BCM, pin 50
Unlock Motor yellow 5wi BCM, pin 44
Parking Lights- N/A
Hazards green/red - hazard switch or BCM, pin 29
Turn Signal(L) green/white + BCM, pin 45
Turn Signal(R) purple/white + BCM, pin 46
Reverse Light purple or red + driver kick, harness to rear
Door Trigger yellow (D), pink (P) - BCM, pins 62 and 12
Dome Supervision purple/red - BCM, pin 48
The step lamps are yellow/purple (-) at the BCM, pin 47.
Trunk/Hatch Pin red - BCM, pin 57
Trunk/Hatch Release pink - BCM, pin 30
The trunk release motor wire is green/white (+) at the BCM, pin 68.
Tachometer NOT white/blue or black ac any ignition coil or fuel injector
Wait to start N/A
Parking Brake lt. green/black or purple/red - parking brake switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Yes Type:
Transponder
Part #: 556UW
Old Sep 15, 2005 | 08:29 PM
Inovashn's Avatar
Inovashn
05 G35
DIRECTWIRE™ WIRING INFORMATION - INFINITI / G35 COUPE / 2005 / Remote Start
Second Ignition N/A
Third Ignition N/A
Parking Lights- N/A
Wait to start N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Yes Type:
Transponder
Part #: 556UW
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
kyin
Oct 15, 2015 05:54 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
nanotech
Oct 2, 2015 05:02 AM
Li1ag
Sep 28, 2015 02:07 PM
