Question about mounting amp in factory sub space
Old Jan 10, 2003 | 12:45 AM
Da Gimp's Avatar
Da Gimp
Default Question about mounting amp in factory sub space
I want to put my amplifier in the subwoofer space (I don't have bose) and I was wondering if I can use any of the metal in there as ground connection?
Also does anyone have a picture of inside that space they could post? I remember one a long time ago, but can't find it.
Basically I want to set up a piece of plywood in there, somehow using existing holes and brackets to fasten it down. Then mount the amplifier / distribution block / capacitor on the plywood. It doesnt have to look pretty because nobody is gonna see it really, but I want it to be very secure.
Old Jan 10, 2003 | 08:53 PM
Anyone2u's Avatar
Anyone2u
Charter Member #82
This is what they did in my sub space. Although they made a fiberglass enclosure in there first, it may give you an idea of the space. The shelf holding the crossovers is plexiglass. I'm not sure about the ground but I really don't think you'll have a problem finding one.
Before:
After:
Old Jan 11, 2003 | 12:22 AM
srobert910's Avatar
srobert910
How do you like your BA Z6's? I'm about to do almost the same thing to my Z. Also Is that the 5 ch. amp or the big 4ch.? Have any problems with the front door window clearence? sorry for all the questions.
Old Jan 14, 2003 | 10:56 PM
Anyone2u's Avatar
Anyone2u
Charter Member #82
Sorry about the response time, but I forgot about this thread. First, I have not heard the system yet as the installation is still not done. BA had to devote all their time to the CES show for the last 3 weeks or so, but that's OK as the car would be "stored" for the winter anyway. As far as the amplifier, that is a "new" amplifier that BA hasn't released yet, but it is a 4 channel amp for the fronts and rears. There is a separate "big" amp in the back for the subs.
As far as door clearance, just like most speakers, they did need a spacer which they incorporated into a "box" they made for the doors. They also did a little metal cutting, but I don't believe that it was really necessary for most applications. You can also see in the picture that they have removed the tweeter from the speaker, and that has been relocated where the stock tweeter was (no picture yet). Finally they are making new grills for the woofers as the stock Nissan grills are not very "transparent" due to most of the perforations being filled in. Here's a picture that may help you.
Old Jan 15, 2003 | 06:17 AM
Subw00er's Avatar
Subw00er
There is a factor ground spot in that area. Stick your head in the compartment and look towards the outside of the car - its pointing backwards. Make sure you dremel it down to bare metal.
issyz
Jul 2, 2017 03:04 PM
kyin
Oct 15, 2015 05:54 AM
Depravity
Oct 1, 2015 04:49 PM
