w7 vs stealthbox
Old Jan 18, 2006 | 03:06 PM
03znj's Avatar
03znj
Know it all
Default w7 vs stealthbox
should i keep my 1 10 w7 and put it in a box or buy the stealth box with 2 w3's? is sound diffrence big?
Old Jan 18, 2006 | 03:28 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
in all honesty, they should sound about the same in terms of output, in s atraightout SPL drag, i would put my money on the 2 w3s, simple matter of more swept area
the w7 MAY, i emphasize MAY, be able to go a little deeper, and be louder at say sub 20hz...but its a toss up...
peroanlly, iw ould go with whcih ever one costs less, and look better to you
Old Jan 18, 2006 | 06:07 PM
B-Unit's Avatar
B-Unit
Thats good advice ^^
Old Jan 19, 2006 | 04:51 PM
03znj's Avatar
03znj
Know it all
well i have the w7 but still have to get a box made . i can afford to get the stealthbox but just wonderign which one is better? i want some real loud bass and that i can feel it to, right now i have the w7 and 500/1 in my closet, so will the w7 hit harder than the w3's?
Old Jan 19, 2006 | 05:05 PM
zsr22's Avatar
zsr22
You really think that 2 w3's in a stealthbox would outperform a 10w7? I think that there would be a clear difference in a 10w7 in a ported enclosure than the 2 10w3's in the stealthbox.
Old Jan 19, 2006 | 05:32 PM
03znj's Avatar
03znj
Know it all
i dont think there are any ported under the strut boxes.
Old Jan 19, 2006 | 05:39 PM
JimRHIT's Avatar
JimRHIT
Your logic is flawed there ... in the fact that low bass requires displaced air .. per your advantage above ... the 2 w3s will outperform the w7.
... anyhow ..keep the W7. It looks nicer, has phenomenal output potential and sounds spectacular when installed properly.
Plus ... telling people you have a W7 is much more impressive than a pair of w3s.
Old Jan 19, 2006 | 05:51 PM
vantage350z's Avatar
vantage350z
2 X 10w3v2-d4 XMAX=.58 in, SD=107 in2, volume displacement=62in3
1 X 10w7 XMAX=.91 in, SD=59.8in2 volume displacement=54.2in3
2 W3's will move more air. I think the W3's is the way to go.. less money also.
Old Jan 19, 2006 | 07:24 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
well, i said may, with a double emphasis on may...
but youa re saying displaced air equals low bass? meaning if a sub displaces more air, it automatically means its deeper?
thats a pretty generic statement dont you think?
what would have higher spl at 10hz?
I. a 10" sub with an xmax of 25mm with a FS of 50 hz (yeah i know such a sub doesnt exist, but it could be done), or a 10" sub with an xmax of 20mm with a FS of 15hz? both in the identical enclosure space of 1 cub feet say?
2. two 10w3v2 in a ported ecnlosure tuned to 100hz, or 1 10w7 in a sealed enclosure? both built to spec.
i know these two are hypothetical questions, but my point is, the design of a sub other than simply mechanical excursion, as well as the enclosure, have alot to do with how deep a sub goes. whcih ia msure you know .hehe
but, as to why i said one 10w7 MAY (again, emphasis on MAY) go deeper, is this:
i am figuring that with two 10w3s, he will be forced to give each sub towards the lower end of the recommend enclosure space. where as with a single 10w7, it can get all the space it wants.
so my question for you is:
whcih of these will be louder at 10hz?
two 10w3v2 in a sealed enclosure each having .65 cubft each
single 10w7 in a sealed enclsoure having 1.25-1.5 cubft
take jl's data, and plug it into your box program and see...
again this is all in good humor, i just wanted to make sure that i wasnt intentionally being contradictive.
Old Jan 19, 2006 | 09:47 PM
CopperZ's Avatar
CopperZ
hands down w7. I heard them both in z's, How do i know? i did a few installs... Thats why i have 2 w7's in my z. =)
Oh and if you need a cheap box, I can get you on thats 189+ shipp. PM me.
bbixby
Oct 20, 2004 05:01 AM
