New rear backup camera with frame
Old Feb 6, 2006 | 06:36 PM
SirZaLot's Avatar
SirZaLot
Originally Posted by Bubble
180 degree with night vision.
I don't mean the rotation of the camera, I mean the angle of the lens.
Old Feb 6, 2006 | 07:36 PM
lololepro's Avatar
lololepro
Will this frame work with eclipse HU's (5435)? It looks like the eclipse camera does not use a standart video cable...
Old Feb 6, 2006 | 08:22 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
they use standard video cable. And once again, i'm still behind in taking the picture.
Old Feb 6, 2006 | 09:33 PM
lololepro's Avatar
lololepro
If you say so I trust you... But in that case what is this connector?
http://www.crutchfield.com/S-2PeGyYM...display=XL#Tab
They also say this :
Compatibility: This rear camera is compatible with select Eclipse AV head units. The 39.25' cable is terminated with a 4-pin Molex connector that plugs into the back of the compatible head unit.
Old Feb 6, 2006 | 09:50 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
hummm...i'm not using the Eclipse camera here bro. I'm talking about the license frame that has the camera build in.
Old Feb 6, 2006 | 10:02 PM
lololepro's Avatar
lololepro
And I'm talking about using the same camera/frame with an Eclipse Headunit... If the eclipse camera has a 4pin molex connector I'm guessing your camera will not work on an eclipse HU... Unless there is some kind of adapter.....
Old Feb 6, 2006 | 10:04 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
is your Eclipse HU has any video output at all?
Old Feb 6, 2006 | 10:19 PM
lololepro's Avatar
lololepro
I don't have one yet, but reading the install guide it has a 4pin input for a rearview camera...
lololepro's Avatar
lololepro
Old Feb 6, 2006 | 11:35 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
seem like they only take Eclipse camera. YOu will need to have HU unit that has regular video output.
Old Feb 7, 2006 | 05:04 PM
charlie_rdstr_Z's Avatar
charlie_rdstr_Z
Get The Pics!
Old Feb 7, 2006 | 11:37 PM
SirZaLot's Avatar
SirZaLot
Bubble,
I don't mean the rotation of the camera. Do you know the degree of the angle of the lens?
Also, is it easy to rotate the camera? Will the camera rotate by the vibration over time?
Old Feb 8, 2006 | 06:07 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
Originally Posted by SirZaLot
Bubble,
why you need to rotate the camera? they are build in the frame. Not like the one we have to drill in our license plate. And again, they are wide angle (180 degree) lens.
Old Feb 8, 2006 | 06:43 AM
GQ 350z's Avatar
GQ 350z
Can you use this frame with any screen or head unit?
ravi
Old Feb 8, 2006 | 08:22 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
ravi
Yes. As long as your HU has video output
Old Feb 8, 2006 | 08:34 AM
barthelb's Avatar
barthelb
Master
IR is used so no one can see your light with the naked eye, just when using Night vision. It emits a light so you can increase your viewable distance at night. Im guessing this camera doesn't have that so you only get what the ambient light is at night. Full moons give you the best visibility.
this is night vision. No need for IR led. I'll try to have the pix asap. Quite busy at work lately.
Old Feb 8, 2006 | 01:26 PM
SirZaLot's Avatar
SirZaLot
Bubble, I thought the camera can be rotate 180 degree up and downward.
Old Feb 8, 2006 | 01:28 PM
  #38
Bubble's Avatar
Bubble
-REPLICA ARMY-
no. It is in fix position.
Old Feb 8, 2006 | 01:31 PM
  #39
SirZaLot's Avatar
SirZaLot
you can't. They secure behind the bumper.
Bubble, also do you need to take off the bumper for installation since they are secured behind bumper? Or take off the plastic cover in the trunk area?
Old Feb 8, 2006 | 01:32 PM
  #40
Bubble's Avatar
Bubble
-REPLICA ARMY-
no. i have after market bumper and still don't have to take it off.
