ok.. so i took on the daunting task of running new speaker wires through the SMJ harness in the doors... damnit
My doors will not lock electronically anymore.. everything else (windows, hatch lock, blah blah) works.. with these 2 wires listed above: Power Lock red - driver door module in door Power Unlock lt. blue (double pulse) - driver door module in door can i troubleshoot the issues? Like as in a voltmeter to see if they are getting juice while hitting the switch? And do the colors for the wires stay the same as they come out the SMJ harness into the door? |
Originally Posted by CaliBoy
check this place out http://www.aubreyandcharles.com/NissanServiceManuals/
I'd like to thank you in advance for doing some backwork on this. I followed wires all around a friends car while working on his audio ( no service manual ) and it was quite a pain.
Thanks again. |
Originally Posted by 16psibrick
audio:
Radio 12v yellow + radio harness Radio Ground (chassis) Radio Ignition lt. green + radio harness Radio Illumination red/blue + radio harness Factory Amp Turn-on green/yellow + radio harness Power Antenna green/white + radio harness LF Speaker +/- blue/red - black/white +,- radio harness RF Speaker +/- yellow/red - red/white +,- radio harness LR Speaker +/- lt. green/red - black/yellow +,- radio harness RR Speaker +/- blue/orange - black/pink +,- radio harness all wiring guide courtesy of DEI i need to know so i can plug them back up :o |
Wire Colors
What are the colors from the headunit for the Front Speakers and Subwoofer?
Coming out of the headunit are there eight (8) total wires for the fronts (Left/Right Woofer/Tweet +/-) or is it only four (4) (Left/Right +/-) and what are the aforementioned colors that represent these wires? Where does the "EQ" take place in a 08 Bose system, within the headunit or within the amplifier? Thanks, I'll be putting on my flame suit... |
Coming out of the headunit are there eight (8) total wires for the fronts (Left/Right Woofer/Tweet +/-) or is it only four (4) (Left/Right +/-) and what are the aforementioned colors that represent these wires? Where does the "EQ" take place in a 08 Bose system, within the headunit or within the amplifier? Thanks, I'll be putting on my flame suit... then open pg.pgf |
Stereo Done / Follow Up
Originally Posted by grumpysmurf
Grab the 07 manual from http://www.aubreyandcharles.com/NissanServiceManuals/
then open pg.pgf After getting into the hatch area, I was able to make sense of what I was reading... My install went well, the splicing was a pain... I wasn't able to get the sub signal to work as planned, so I just tapped into the signal from the fronts fed it through a crossover and sent it to my subs. Anyone that says JL is just a name has never used their Cleansweep product, worked amazingly well, I am very impressed by how easy it was to install, and how well it "cleaned" up the stock signal. I understand what people mean about the bass response from the stock location... i have the box firing upwards in the stock sub location... there just is not enough room for the sound to propagate correctly... I am not sure what I will do to fix this problem... Any advice would be welcomed in this department... Focals are definately worth the hype, but I will probably upgrade to Seas at some point in the future... older ears do not do so well with tweeters that can shatter glass. Thanks for the help |
FYI for anyone looking to splice into the Parking light circuit w/o having to go to the fuse block in the engine bay...
Btw, this was on an '03 Z Driver's kick panel, above the fuse block http://jon.capcik.com/pics/z/wiring/...ight_wire1.JPG Red w/ Blue stripe http://jon.capcik.com/pics/z/wiring/...ight_wire2.JPG Had to cut some of the zip ties holding the loom because it was very hard to bend (noted in yellow, one further up as well). It's also pretty hard to get a screwdriver up there to pop the clip loose. The red circle is where the white/blue ignition (ie. switched) wire is as well. http://jon.capcik.com/pics/z/wiring/...ight_wire3.JPG Hopefully this helps someone out, since there isn't much info on it, and there are multiple red/blue wires in the driver's kick panel. |
Subbed for the future wiring info. Thanks Guys.
Nice info....
2006-2008 Wiring
Here is the DEI wiring for 2006-2008 models
Item - Wire Color - (Polarity) - Wire Location 12 Volts - Green (40A) - (+) - Ignition Harness Starter - White/Red - (+) - Ignition Harness 2nd Starter - White/Green - (+) - Ignition Harness Ignition - Black/Red - (+) - Ignition Harness Accessory - White/Black - (+) - Ignition Harness Keysense - Black/Red - (+) - Ignition Harness or BCM in driver kick, pin 37 Data Bus - Yellow - (Data) - Driver kick or BCM in driver kick, pin 22 Can Bus High - Blue - (Data) - Data link connector under driver dash, pin 6 Can Bus Low - Pink - (Data) - Data link connector under driver dash, pin 14 Power Lock - Black/Red - (-) - Driver door module in door, pin 6 Power Unlock - Lt. Blue (Double Pulse) - (-) - Driver door module in door, pin 7 Lock Motor - Purple - (5 Wire) - BCM in driver kick, pin 50 Driver Unlock Motor - Yellow - (5 Wire) - BCM in driver kick, pin 44 Passenger Unlock Motor - White/Red - (5 Wire) - BCM in driver kick, pin 51 Parking Lights (+) - Red/Blue - (+) - Driver Kick, harness to rear Hazards - Green/Red - (-) - Switch or BCM in driver kick, pin 29 Turn Signal (Left) - Green/White - (+) - BCM in driver kick, pin 45 Turn Signal (Right) - Purple/White - (+) - BCM in driver kick, pin 46 Headlight - Red/White (L), Red (R) - (+) - Lights or IPDM E/R, gray 16 pin plug Reverse Light - Orange or Lt. Green - (+) - Driver Kick, Harness to rear Left Front Door Trigger - Blue - (-) - BCM in driver kick, pin 62 Right Front Door Trigger - Pink - (-) - BCM in driver kick, pin 12 Dome Supervision - Pink - (-) - BCM in driver kick, pin 48 Trunk/Hatch Pin - Red/White - (-) - BCM in driver kick, pin 58 (Coupe) or 57 (Conv) Hood Pin - Lt. Green/Black - (-) - Hood pin switch under hood Trunk/Hatch Release - Pink - (-) - BCM in driver kick, pin 30 Trunk Release Motor - Blue/Red - (+) - BCM in driver kick, pin 68 Fuel Door Release - Blue/Red - (-) - Release switch on dash Factory Alarm Arm - Arms With Lock Pactory Alarm Disarm - Disarms with Unlock Disarm No Unlock - Single Pulse on power unlock wire Tachometer - NOT White/Blue, Black, or Red - (AC) - Any ignition coil or fuel injector Speed Sense - White - (8P) - Unified Meter and A/C Amp, pin 26 Brake Wire - Pink/Blue - (+) - Brake Pedal Switch Parking Brake - Purple/Red - (-) - Parking brake switch Horn Trigger - Green/Black - (-) - Horn Switch Wipers - Blue (L), Blue/Black (H) - (+) - Motor or IPDM E/R, gray 16 pin plug Left Front Window (Up/Down) - Blue - Green - (A) - Driver window switch in door Right Front Window (Up/Down) - Blue - Green - (A) - Passenger window switch in door Sun Roof (Open/Close) - Blue/Black - Red/Green - Soft top switch on dash Wiring Notes: Can Bus High - Also found at the BCM in the driver kick, pin 39. The security light wire is Green/Orange (-) at the BCM in the driver kick, pin 23. Can Bus Low - Also found at the BCM in the driver kick, pin 40 Power Lock - Meter this wire while turning the key in the driver door key cylinder Power Unlock - Meter this wire while turning the key in the driver door key cylinder Headlight - The IPDM E/R (Inteligent Power Distribution Module Engine Room) is between the passenger fender and the battery Speed Sense - The Unified Meter and A/C Amp is behind the A/C controls in the center console Wipers - The IPDM E/R (Inteligent Power Distribution Module Engine Room) is between the passenger fender and the battery Left Front Window (Up/Down) - Extended triggers on the power lock/unlock wires will also roll the windows up/down Sun Roof (Open/Close) - These wires are for the convertible top open/close. They only function with the ignition on and the brake pedal pressed. |
OK...I have looked all over online and on here and tried to go by the wiring color codes...but my 03 Z doesnt seem to match up.....am I missing something?
Yellow Light Blue Red/Yellow Light Green Gray Gray (yes 2 of the same color) White Red/Blue Orange (or orangeish brown) Dark Green Red Pink Green/Yellow Black Black/Red Green/White And I am trying to match them up to what is listed here and on other sites...cant quite figure it out... HELP!!!! |
it really is a tough job..hope someone can help..but im sure that when it comes to wiring problems,, the autometer would be of great help in troubleshooting..:werd:
At the speaker in the rear, which one is + and which one is -, all I can find is information on the wiring harness at the headunit
nm, the Enercell 12v DC accessory i got was bad. i bought a new one and it works fine now.
How about the plug on the passenger side. Any skamatic on how to put that back together?
Originally Posted by Frank311
(Post 9054657)
I never took it apart. I just unplugged the harness going into the back of it, used the included wire splicers that came with the accessory, spliced them together, and then plugged the harness back in. |
This is the information i need but the pictures dont work, can anyone help me out. Im trying to hook up the wire from my Pioneer AVH4300 that lets it know the car is in reverse for the backup camera.
Originally Posted by JonnyC
(Post 5460495)
uber old thread bump.. does anyone know what color wires in the doors that give the switch panels illumination - and + are?
I cant find anything for the life of me online, and im pretty darn saavy. |
i have the same issue. i know it's been outdated. just intalled a kenwood ddx7015 and the speakers are clearly not correct. these are the right colors coming from the car, not the ones mentioned in any of the guides. -___- help?
Originally Posted by adidasink
(Post 7319740)
