NEED HELP!!! short circuit
Old Mar 21, 2006 | 12:47 PM
zero0 2 sixty's Avatar
zero0 2 sixty
Exclamation NEED HELP!!! short circuit
guys i just installed a new system in my car.its 2 rockford punch p3s and 2 pioneer 800watt amps. i keep blowin fuses like crazy. is there a short ...any advice im open to any ideas.
Old Mar 21, 2006 | 01:11 PM
Mike Wazowski's Avatar
Mike Wazowski
which fuses? the inline fuse close to the battery? Are you using the correct fuse? If you are going to post please give information for use to go on and help you with.
Old Mar 21, 2006 | 01:14 PM
dream724Z's Avatar
dream724Z
With an ohm meter, disconnect your amps and check for a short (both power line and speaker leads). 1600W RMS is 133Amp, what size fuse is blowing? If the fuse is sized right and no shorts, then try some new amps.
Depravity
Oct 1, 2015 04:49 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
ddegrande21
Sep 6, 2015 11:15 AM
