Speaker Baffles?
Old Mar 23, 2006 | 12:41 PM
umzzz's Avatar
umzzz
Cwest Army
Default Speaker Baffles?
Does anyone have experience with speaker baffles for the midrange speakers up front. I made a spacer out of MDf to mount the speaker and it doesnt sit exactly flat against the door so just wondering if this is a good way to seal up the speaker:
http://www.crutchfield.com/S-kLKZRSx...=762&I=237XT65
thanks for the help
Old Mar 23, 2006 | 12:55 PM
deviantC's Avatar
deviantC
I've used that exact brand on several installs and think they help the sound. I trimmed mine to match the speaker rim, wired and soldered connectors to the posts, then punched a small hole through the baffle for the wire lead, sealed that back up with super glue, and glued the baffle to the speaker rim for a "sealed" enclosure. It definitely gives slightly better low end response.
Note, I've never done it in my Z. These installed were in a Civic Si, and a Ranger, but the concept remains.
Old Mar 23, 2006 | 01:47 PM
JimRHIT's Avatar
JimRHIT
Those are a bad idea for our car, as they will stick too far back and interfere with the windows. So if a window motor goes (common problem on Zs) your dealer will tell you to go kick rocks
Go to Home Depot or any other improvemnts store. Pickup a bit of gasket tape, weather stripping or anything they have that is essentially sticky foam tape. This can usually be found in windows and doors sections.
Should be a $5 for a rolll that can do about 20 cars
Old Mar 23, 2006 | 02:33 PM
james840a's Avatar
james840a
Those arent a bad idea, i have them in my car. They come in shollow mounts aswell. http://www.crutchfield.com/S-YfFVGHo...762&I=237XT652
3vilbunny
Jul 18, 2017 05:10 PM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
