Group Buy New Roadster / Coupe Enclosure
Old Apr 28, 2006 | 05:42 PM
Georgidis's Avatar
Georgidis
Will A Cdt Audio es 10" fit. Depth specs are 5 5/8” ( 177mm). I know its a little longer then you say will fit, but just curious.
Old May 3, 2006 | 09:23 AM
Nazar's Avatar
Nazar
Default Final Product pics addes
Here are the final product pictures...
It will get bolted on in the same wholes as the factory pocket there...
The install is simple. Just take the factory pocket out and install the sub enclosure... It will slide in and out just like the factory Glove Box...
Old May 4, 2006 | 08:42 AM
Nazar's Avatar
Nazar
They will start shipping 5/5/06. Thank you for all the pre-orders. There is only 3 spots left in the Group Buy.
Old May 10, 2006 | 06:46 AM
Nazar's Avatar
Nazar
First batch shipped.
Keep in mind when you get the enclosures you will need to drill holes on the lip of the enclosure to match with the mounting holes. And simply use the bolts that was used to hold the stock pocket in place to secure the fiberglass enclosure.
Old May 10, 2006 | 01:18 PM
BamBam's Avatar
BamBam
Talking
I just wanted to say it sounds GREAT... The Bass can be set up to be MORE then you can stand inside the car. But it is still clear as a bell and responsive as hell....
Enjoy them guys... I certainly am.
Old May 10, 2006 | 04:43 PM
beggohbee's Avatar
beggohbee
Can you comment on any rattling and if you had to put in sound deadening?
Old May 10, 2006 | 04:48 PM
BamBam's Avatar
BamBam
I know they put in some extra dynomat, but I think Nazar would have to comment on where it was placed.
I do not hear any rattling from the back at all. Now, if I have the mids up too high, I can hear my CF door panels rattle, but that has always done that because of some lose connections on the panel itself.
I think it sounds great and I know these guys did a great job with the installation.
-B
Old May 11, 2006 | 05:41 PM
bjr's Avatar
bjr
So, it looks pretty obvious to me that to remove the glove box you need to remove all of the side rear trim and large cubby trim to get it out? Or is there a simple way?
Old May 16, 2006 | 10:14 AM
Nazar's Avatar
Nazar
Yes.
Old May 16, 2006 | 05:17 PM
350ztoronto's Avatar
350ztoronto
hey nazar, will this fit a jl 10w3 ?
if so im in ^_^
Old May 18, 2006 | 05:59 PM
nearly zer0's Avatar
nearly zer0
I'm very interested, though it seems like wickedcas.com is not up right now and I have yet to see a pic of the boxes.
Also, I own a set of 8 inch infinity subs that I was going to make custom boxes for, could I drop these into your enclosures with an adaptor ring or something?
Old May 19, 2006 | 05:45 AM
Nazar's Avatar
Nazar
The site must have been down when you were looking, There are pictures in this thread. And as far as your subs... The cutout on the box is for a 10" I can have it cut for 8: however I need your depth. And It may be a little too big for an 8" sub.
Old May 19, 2006 | 07:00 AM
nearly zer0
recommended sealed box size is .35ft
recommended ported box size is .6ft
mounting depth is 4 5/16" or 110mm
This is an Infinity reference 8" sub. Will it work?
edit: I am only interested in the driver side as I kind of like having the little compartment behind the pass. seat. If the box is too big for 1 sub, would it make sence to cut a hole in the side facing the back of the drivers seat and drop the other 8 in? so 2 subs would be sharing the same box.
Old May 19, 2006 | 01:09 PM
Nazar's Avatar
Nazar
Physical dimension it will fit. But the box is just too big for that sub. I would NOT face them towards the driver since that defeats the purpose of this enclosure.
Old Jun 5, 2006 | 05:49 AM
teh215's Avatar
teh215
What happened to the pics?
Old Jun 5, 2006 | 12:56 PM
sdbarker's Avatar
sdbarker
So, I've seen two prices so far, $30 and $80...
Which price is accurate?
Old Jun 9, 2006 | 05:54 AM
Nazar's Avatar
Nazar
$30 and $80 for what?
Old Jun 9, 2006 | 06:09 AM
  #38
sdbarker's Avatar
sdbarker
For the sub boxes.
Old Jun 9, 2006 | 06:18 AM
  #39
josh846's Avatar
josh846
sdbarker read the very first post. that gives the prices. and if you honestly think someone would be selling enclosures for 30-80 you have lost your mind and know nothing about this kind of stuff.
Old Jun 9, 2006 | 08:16 AM
  #40
sdbarker's Avatar
sdbarker
I missed the prices in the first post and only saw the near $80 figure. I definitely haven't lost my mind, which would explain why I was confused about it.
