bose amp location
Old Apr 24, 2006 | 01:32 PM
drew76924's Avatar
drew76924
Default bose amp location
where is teh bose stock amp located i can't seem to find it
Old Apr 24, 2006 | 01:59 PM
Swiffer's Avatar
Swiffer
its in the same compartment that the sub is in. You have to remove the sub and you'll see the amp behind it.
Old Apr 24, 2006 | 02:01 PM
Santacruzslick's Avatar
Santacruzslick
Veteran
That's just for the sub, the bose amp for the rest of the speakers is under the large plastic piece in the trunk on the drivers side. It's a ***** to get to. Gotta take apart most of the trunk to get in there.
Old May 2, 2006 | 10:29 AM
drew76924's Avatar
drew76924
i took everything apart and i could only find the one behind the sub
Old May 3, 2006 | 04:07 PM
dbpoet's Avatar
dbpoet
Keep looking, it's there. I knoe because I yanked thatPOS out of there.
Old May 3, 2006 | 04:22 PM
Santacruzslick
Veteran
Ok, remove the trunk mats, spare tire, all that garbage. Then remove the driver side rear quarter interior panel and the panel against the rear of the trunk. There is a large black plastic piece sitting in the trunk molded into the rear driver side corner, it needs to be removed. You will find the BOSE amp beneath it.
Old May 3, 2006 | 09:41 PM
drew76924's Avatar
drew76924
alright thanx
Old May 4, 2006 | 07:25 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
The four channel one is located under the antenna on the port side of the stern.
(land lubbers )
Old May 5, 2006 | 10:39 AM
drew76924's Avatar
drew76924
(land lubbers )
10-4; rodger that, i'll verter to the antenna area vectoring bravo delta foxtrot
kyin
Oct 15, 2015 05:54 AM
Tochigi_236
Sep 27, 2015 03:40 PM
