stealthbox speaker advice needed
Old May 2, 2006 | 04:48 PM
rx7/350z's Avatar
rx7/350z
Default stealthbox speaker advice needed
ok .... thanks for the responses last time ,but lets try this again.
1. I have a jl audio stealth box with no speakers in it.
2. I have a kenwood x811d 400wats rms at 4 ohm and 800 rms at 2, also 1 ohm stable.
what JL subs should i put in it to get the most out of my setup
w3's /what ohms and single or dual vc's or w6 if someone knows it the box is deep enough. the seales box size for the w3's and w6's are very similar .5-1.0 and .6 to .9 cuft
Old May 3, 2006 | 09:47 AM
Nazar's Avatar
Nazar
I am not sure if you have the depth but you can try the 10w6 subs. If depth is an issue you can try speaker rings, If that does not work either, Try one of our Fiberglass enclosures.
Old May 3, 2006 | 12:14 PM
drifter23's Avatar
drifter23
If you need more spec's or info on the JL Stealthbox you can go to this website: http://mobile.jlaudio.com/products_s...hp?fit_id=1416
Old May 3, 2006 | 02:53 PM
CaliforniaZman's Avatar
CaliforniaZman
the box is built for the 10w3's
Old May 3, 2006 | 03:17 PM
rx7/350z's Avatar
rx7/350z
i am well aware of that, thanks
sherm
Apr 11, 2020 05:21 PM
3vilbunny
Jul 18, 2017 05:10 PM
kyin
Oct 15, 2015 05:54 AM
