avic Z1 install in 06z, service light on. HELP.
Old May 17, 2006 | 12:49 AM
evobunny's Avatar
evobunny
Default avic Z1 install in 06z, service light on. HELP.
Ok guys I just install my avic Z1, and it kick on my service soon light. Anyone know what the deal, and what I can do about it.
Also some time I cant get the light bypass method to work. Dont know if my timing is off or what. Should I turn it fast or slow at the boot up screen which show the pioneer sign.
Also I get the message for improper ground and that I should check it, but the bypass work. Is that post to happen.
Old May 17, 2006 | 05:55 AM
tekk's Avatar
tekk
try an ecu reset to fix the service light..
Old May 17, 2006 | 07:41 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
My Pioneer AVIC N2 complains after every time I disconnect the battery to do any work. While letting the car idol I'll cycle the hand brake a couple of times and it goes away.
Old May 17, 2006 | 10:12 PM
evobunny's Avatar
evobunny
Originally Posted by rich150001
Just unplug your battery for a few minutes. It happened to me during my install as well.
dont think the battery method works
Old May 18, 2006 | 06:19 AM
06blueZ's Avatar
06blueZ
Question
Iv heard that the 06 radios are tied in to some of the diagnostic functions, like the mute and power button does things with the ECU. Can anyone confirm this? If this is the case, this may be the caue of your CEL. anyone else get the light after an 06 radio swap?
Old May 19, 2006 | 04:44 PM
hcwlsu's Avatar
hcwlsu
Give it a day or so. If you powered up the radio before you plugged in the AC/Heater controls it will do this. It will go away after a couple of days.
Old May 19, 2006 | 11:10 PM
evobunny's Avatar
evobunny
you know what, that is exactly what I did. I didnt connect the ac/heater control plate. Cause I was just trying to hurry and test something. Man I hope it will go away like you say. But it has been a couple of days already.
By the way, does anyone know when the services soon light should come on, like how many miles and stuff.
Paul350Z
Audio Builds
41
Mar 12, 2008 10:42 AM
farber
May 23, 2006 07:47 AM
SteveZ33
May 19, 2005 08:43 AM
SteveZ33
Apr 27, 2005 08:56 PM
Paul350Z
Apr 24, 2005 10:22 AM
