Kenwood DDX-6019 Signal Quality
Old May 24, 2006 | 06:53 PM
drumma022's Avatar
drumma022
Default Kenwood DDX-6019 Signal Quality
I just recently installed my DDX-6019 into my '03 Touring, and I am slightly disappointed that the signal quality is very poor. In Orlando, I can only catch about 5 stations on the SEEK and when tuning into the station, 3 of my favorite stations are about 60% of what it should be.
I know the antenna is hooked up because I used the antenna wire as the radio ground so if it becomes disconnected, it will turn off.
Does anybody else experience this problem?
Old May 24, 2006 | 07:02 PM
gt3's Avatar
gt3
Mine is pretty good...did you connect the blue antenna cont. wire from the headunit to the Green/White wire on the OEM harness? If you did not, the anntenna amp will not turn on.
Old May 25, 2006 | 05:20 AM
mandm177's Avatar
mandm177
same here, mine works fine as well...
Old May 25, 2006 | 05:35 AM
kitkos's Avatar
kitkos
It's the antenna wire. Several other people on this site have had the same issue.
Old May 25, 2006 | 05:56 AM
drumma022's Avatar
drumma022
Yea - that was the problem. Interesting that I searched DDX-6019 and read a bunch of threads, but I must have missed it. THANKS GUYS! Works awesome now. Its picking up stations I never new existed.
Old May 25, 2006 | 02:26 PM
kitkos's Avatar
kitkos
Glad that fixed it for you.
Since you searched DDX-6019 you were limited to that particular model.
Kewood has had at least two other models that people on this board are using. DDX-7015 DDX-8017 and possibly more. they are all pretty much the same just newer models and eXcelon vs. Kenwood.
Old May 25, 2006 | 10:57 PM
gt3's Avatar
gt3
Good to hear you got it fixed
350Z_Al
Oct 29, 2020 07:44 PM
dcains
Nov 11, 2015 11:36 PM
Tochigi_236
Sep 27, 2015 03:40 PM
