Where do you get the cigarette lighter wire?
Old Sep 12, 2006 | 09:46 AM
blofeld9999's Avatar
blofeld9999
Default Where do you get the cigarette lighter wire?
I'm doing a basic Carputer install in the glove compartment. I need switched power (only on when the car is on) as an input to the power supply which will also be in the glove compartment.
Where can I get a signal for this? I was thinking of using the cigarette lighter. Is the wire running to the cigarette lighter in the center console (where the shifter, etc is)? Or do I have to remove some other panels to get at it?
My worst case scenario is running a wire from the head unit all the way to the glove box.
Thanks for any info.
Old Sep 12, 2006 | 09:47 AM
sq40's Avatar
sq40
There is a lighter right next to the glovebox too you can use.
Old Sep 12, 2006 | 09:58 AM
blofeld9999
Yeah, that's the one I was going to go with. I guess there's a wire I can splice going to that cigarette lighter socket. My question is how to get to that wire. Right now I'm trying to figure out how to route everything I need to the glove box behind the passenger seat.
I'm a noob as far as all this goes. I appreciate the help.
Old Sep 12, 2006 | 10:00 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
You can reach right up under the dash and grab it with your fingers IIRC.
There is a locking jack that connects to the back of the lighter. Use a 3M Scotchlock connector to splice into that wire - I think the blue color is the proper diameter.
sq40's Avatar
sq40
Just pry up on the bottom part of it and it snaps right out. There is about 2" of slack in the wire when you get it out.
Old Sep 12, 2006 | 10:05 AM
Hybrid90's Avatar
Hybrid90
Haven't opened up the glove box yet but you can just drill a tiny hole in the side or back of the glove box and run all your wires through there. The power wire that goes to the cig lighter should be right behind the lighter piece itself. All this info is based on my installation in my old integra, not with the Z but you should get an idea of how to do it.. OR you can always ask this Z member since he's doing the same thing as you:
https://my350z.com/forum/audio-builds/212129-my-carputer-setup-streetdeck.html
Old Sep 12, 2006 | 10:48 AM
blofeld9999
That's the info I was looking for. Thanks for the quick replies everyone.
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
