Speaker wire
Old Mar 14, 2003 | 09:26 PM
CaneZMD's Avatar
CaneZMD
Default Speaker wire
For those who changed the Front separates, did you use the factory speaker wires or did you rewire the new separates.
If you rewired, how did you get the wire into the door.
I installed Infinti Kappa separates a while back, but I'm installing my amp this weekend. I usually rewire, but I know that could be quite a hassle.
Thanks for the help.
Old Mar 15, 2003 | 01:07 AM
Ludecrew's Avatar
Ludecrew
just use the stock wire should b efine
Old Mar 15, 2003 | 07:04 AM
Mikey Likes It's Avatar
Mikey Likes It
Charter Member #44
I did use new wire, and yes, it was a hassle running it. But I didn't want to take a chance on making the speaker wire the weakest link in the system.
Mike
Old Mar 15, 2003 | 08:09 AM
AAAA's Avatar
AAAA
how much did new speaker wire cost you guys... i was having the same delema
Old Mar 15, 2003 | 05:34 PM
Cintel7's Avatar
Cintel7
You need to change your wire if you are running a good system. Otherwise, leave everything stock. what a good wire gives you is controlled mids and highs. Vocal has more air and tweeters sounds smoother at higher volume.
If you have a nice system, do your system a favor and upgrade the wires. Go to your high end home audiophile center and see if they have anything for cheap.
Old Mar 15, 2003 | 05:58 PM
Mikey Likes It
Charter Member #44
This is what I used:
Rockford Fosgate Wire
It is .69/foot. Here's a quote:
"Looking for the ultimate speaker wire? Rockford’s Type RF Competition series features Riot Gamma Geometry with three cores (PC-OFC copper positive and negative, and an inductive control core) for sonic accuracy. Since the conducting wires cross each other at 90 degrees, unwanted noise is canceled more effectively than other twisted speaker wires. The overall length of the Riot Gamma Geometry wire is similar to conventional speaker wire since there is no “twisting” resulting in minimal added resistance. 15 gauge (1.65mm²). Sold by the foot."
A litte hard to run because of the 3rd wire, but no big problems. I used it for the front and rear speakers, and have a heavier gauge ready for when my sub enclosure is done. I ordered 25-30 feet of it and had a little left over when I was done.
Good luck!
Mikey
350Z_Al
Oct 29, 2020 07:44 PM
3vilbunny
Jul 18, 2017 05:10 PM
kyin
Oct 15, 2015 05:54 AM
nanotech
Oct 2, 2015 05:02 AM
