Kicker Cvx10-4 Comp Vx L7 10"
the CVX4-10: 600 Watts RMS w/ dual 4 ohm VCs each. (round)
*I don't think they're called an "L7"...is your round or square (L5 or L7)?
you could run them together at either 1 ohm or 4 ohm, so find an amp that will ouput around 1200 Watts at 1 or 4 ohms.
here's their website:http://www.kicker.com/06/kicker_home.html
-Peter
-Peter
i'm going with the same 10's (cvx's) but they are dual 2 ohm so i can run them to an amp at 2 ohms. the amp i decided to use was the kicker zx1000.1...should provide enough power, maybe around 550 watts rms to each 10. i should have it set up by the end of the weekend. your best bet would be to get on caraudio.com and search their amp forums for a good amp that is 1 ohm stable. i know that is possible...not sure about running an amp at 4 ohms and getting enough power for both the 10's
