Sat Nav Retrofit - Help Needed
Old Mar 23, 2003 | 12:41 AM
veilside z's Avatar
veilside z
Question Sat Nav Retrofit - Help Needed
Help me people,
In the UK we are not going to get the Sat Nav option, but I would like to fit a unit to look as stock as possible. So I need a bit of info, re. sizes & part numbers etc...
1. What is the part number for the GPS antenna that is mounted under the dash top on the driver's side?
2. What is the overall size (w x d x h) of the standard Nissan Navi Control Unit that is fitted in the Rear Panel above the Sub/Storage Area?
3. What are the Part Numbers for the Panel Finisher in Black (to surround the Navi Control Unit?
4. What are the Part Numbers for the Two Support Brackets that hold the Navi Control Unit?
5. What is the overall size (w x d x h) of the Sat Nav Screen?
6. What is the Part Number of the Sat Nav Screen?
7. What is the Part Number for the Support Bracket that holds the screen?
If anyone can help me out with (any part of) this info., I should be able to source a UK system that I can then integrate into the Z to look totally stock...
Any information would be much appreciated...
Thanx
Justin100
Nov 25, 2021 06:26 AM
sherm
Apr 11, 2020 05:21 PM
kyin
Oct 15, 2015 05:54 AM
