Need help with double din kit
Old Jan 9, 2007 | 04:09 PM
orangeZ89's Avatar
orangeZ89
Default Need help with double din kit
i have ordered the panasonic cq-vd6503u and i need a din kit. are there any double din kits out there where you dont have to do any modification to take out the pocket. please help asap ive been looking through the forums and cant find anything.
Old Jan 9, 2007 | 04:49 PM
bay350z's Avatar
bay350z
The metra one you don't. It comes with both parts for both single and double din. I got mine at circuit city for $20.
Old Jan 9, 2007 | 04:55 PM
orangeZ89's Avatar
orangeZ89
im pretty sure you do. thats what ive been looking at. what brand and model # did you get?
Old Jan 9, 2007 | 05:01 PM
orangeZ89's Avatar
orangeZ89
Old Jan 9, 2007 | 05:16 PM
bay350z's Avatar
bay350z
Its the 99-7402 There is a bracket just for dd and you just have to clip the middle, no big deal. The bracket with the pocket you dont even touch.
Old Jan 9, 2007 | 05:38 PM
orangeZ89's Avatar
orangeZ89
what do you mean clip the middle part? You cant just take the pocket off can you?
Old Jan 9, 2007 | 09:43 PM
bay350z's Avatar
bay350z
There is one bracket for the DD and one for Single the one for the DD has a bar in the middle incase you want 2 SD decks. If you done you cut out the center.
Old Jan 10, 2007 | 04:25 AM
orangeZ89's Avatar
orangeZ89
oh thats good to hear thanx for your help! What system do you have in your car?
Old Jan 10, 2007 | 04:36 AM
Lsmith9523's Avatar
Lsmith9523
I have an 06 and running the Alpine W-200 doubledin. The metra kit I bought for the 06, I only used the doubledin trim piece. It was already a doubledin set up with no cutting. I think the metra kits for the earlier year cars, you had to snip the middle plastic piece in the middle.
Old Jan 10, 2007 | 04:50 AM
orangeZ89's Avatar
orangeZ89
yah thats what ive heard. how did you go about mounting the unit?
Old Jan 10, 2007 | 06:36 AM
bay350z's Avatar
bay350z
I will find out this weekend. I have a 3 day weekend so i am gonna install the hu and speakers/amp this weekend. I can't wait. I will let you know how it goes.
Old Jan 10, 2007 | 12:46 PM
orangeZ89's Avatar
orangeZ89
ok cool yah im waiting for it to come in cant wait hopefully it will go good and will be easy thanx for your help
Old Jan 10, 2007 | 12:49 PM
240Zplus110's Avatar
240Zplus110
Metra Dash Kits:
03-05 Z -- #99-7402
06 Z -- #99-7602
Metra Wiring Harness: (same for all model years) -- #70-7550
Old Jan 10, 2007 | 12:55 PM
Lsmith9523's Avatar
Lsmith9523
When mounting the double din headunit....Again, I only used the DD trim piece from my metra kit...I used the factory mounting brackets from factory headunit, which attach to each side of your new headunit,,,then attach back to console, then attach console back to car...If you have any questions,,,please feel free to PM me. I can talk you through it. I think once you get it apart and look at it,,you will see what I am talking about (using the factory mounting brackets) I hope this helps,,good luck. Post pics of your install, like to see how it came out.
Old Jan 10, 2007 | 02:34 PM
orangeZ89's Avatar
orangeZ89
yah it doesnt seem that hard thanks for the info. ill deffinitally post pics. the only concern i have is that i had a place install my old headunit and i think they took something the helps the stock headunit mount into the dash but, i cant figure out what it is. is there a piece that goes there because i basically just have a whole with no way to mount anything
Old Jan 10, 2007 | 02:41 PM
350zx6r's Avatar
350zx6r
I have an extra 2006 metra kit for sale.....
Old Jan 10, 2007 | 06:16 PM
Dr.Z's Avatar
Dr.Z
If you've got an 03-05, you could go to:
www.japanparts.com
E-mail them and ask them for:
Part Code 28074
Part Number *68105-CD000 Audio Finisher
Which is the Nissan Double DIN frame. More expensive and takes a little longer, but no problems with it matching the interior. Depends on how picky you are.
This is what it looks like:
Old Jan 21, 2007 | 01:30 PM
pulser8's Avatar
pulser8
Did you use the spacers when attaching the factory mounting brackets to the H/U? Also, with your metra kit did you have to clip the center from the trim piece?
Old Jan 21, 2007 | 04:34 PM
bay350z's Avatar
bay350z
Yea, i used the spacers and it fit perfect, also youdo have to clip that center piece. I need to back and shave a bit from the top cause the deck has a hard time opening, i have the 6800.
Old Jan 21, 2007 | 05:01 PM
pulser8's Avatar
pulser8
Thanks. I need to do some adjustments my self as I could not get the lower part of the console to seat back under the deck. All in all...not a bad install tho.
EnjukuRacing
Sep 30, 2015 06:55 AM
