quick 12v help
Old Feb 28, 2007 | 11:53 AM
MUZZY's Avatar
MUZZY
Default quick 12v help
hey guys just installed some guages on the pillar and it requiers a constant 12v source. What is the closest and easiest thing that I can locate and splice to under the driver side?
the guages i got also require an ignition 12v witch tells the guages to turn on when the key is in but the constant 12v is to save my functions and settings when the car is off.
hoping for a quick reply, pics are apritiated. thanks ahead of time!
p.s. thx shane for helping me install these
Old Feb 28, 2007 | 01:11 PM
first350's Avatar
first350
you can tap into the fuse box, it's on the driver's side under the dash. if you want a switched power source, you can tap into the stereo's power (there's 2, 1 contsant and 1 switched)
-Peter
Old Mar 1, 2007 | 01:57 PM
MUZZY's Avatar
MUZZY
k thx
Old Mar 1, 2007 | 02:12 PM
Barmats's Avatar
Barmats
Invest in a test light or voltmeter - it's indispensable for wiring projects, and you'll use it over and over again. I still use the one I bought in 1978 for car wiring.
lapham3
Oct 7, 2022 03:15 PM
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
