Need a new Battery, Looking at this one!
Old Mar 5, 2007 | 07:22 AM
james840a's Avatar
james840a
Default Need a new Battery, Looking at this one!
My battery is not holding a charge, and need a new one. Im thinking about this size, but wanted to get opions, is this too large of CCA for the car? Im going with this brand because the company is down the street from me and easy to obtain. Ill be getting a battery at lunch time.
PC1200:
http://www.odysseybatteries.com/battery/pc1200mjt.htm
PC925:
http://www.odysseybatteries.com/battery/pc925mjt.htm
Old Mar 5, 2007 | 09:07 AM
james840a's Avatar
james840a
Ok been searching in past posts, and some guys are Running the PC680. How will that do on a stock Z with a 1.3k watt to 1.6k watt sound system?
Old Mar 5, 2007 | 09:35 AM
jmckuhen's Avatar
jmckuhen
I don't think this is the battery you are looking for as this is mainly used by guys trying to save weight for racing purposes. Why don't you try an optima battery, since they are mostly used for your application.
http://www.optimabatteries.com/publi...utomotive.html
Old Mar 5, 2007 | 09:41 AM
StreetOC192's Avatar
StreetOC192
I've had nothing but good luck with the Exide Orbital battery. In my opinion, it is a better battery than the Optima and it can usually be found a little cheaper.
http://www.exide.com/products/automo...bital_XCD.html
Old Mar 5, 2007 | 09:47 AM
james840a's Avatar
james840a
What about the PC1200? im looking at this brand because they are just down the street from were i work, and need a battery at lunch.
Old Mar 5, 2007 | 09:49 AM
jmckuhen's Avatar
jmckuhen
yeah you should be fine with that one
Old Mar 5, 2007 | 10:02 AM
james840a's Avatar
james840a
Cool Thanks,
I just call them and ill be picking it up at lunch. Got a Co-work to drive over me over there.
Old Mar 5, 2007 | 03:47 PM
icedoutis's Avatar
icedoutis
I had nothing but bad luck with the optima batteries. Went through 7 of them in my last car (over a 3 year period).
Old Mar 5, 2007 | 03:57 PM
eltness350's Avatar
eltness350
The Untouchable
i have the pc-680 with upgraded speakers in the factory spots (non-bose/ no sub) , works great and weighs 12lbs, i weighed the factory battery, 37lbs. ...(pig) def not for a 1k watt system...dim headlights prob...
Old Mar 5, 2007 | 06:39 PM
james840a's Avatar
james840a
Update,,, I got the PC1200 and just finished installing the mounts. This one is nice it fits the stock location nicely, except the mounting bolts, just need to be shorter.
Old Mar 5, 2007 | 08:47 PM
Z1truth's Avatar
Z1truth
The Hawker PC1200 is top of the line....I have 2 PC1800's in my 300Z with a 1600 RMS system and am very happy!
Old Mar 6, 2007 | 06:38 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
At 1600 watts you're pulling +120 amps from your battery - figure a big one will last about 30-40 minutes and still be able to possibly start the car. My home's USP has 106 lb gas absorbed mat batteries rated at 260 amp hours which would drive that 1600 watt system for about two hours. The alternator of the Z will barely keep up with a 120 amp demand and don't dare drive with the headlights on too.
Ever wonder why at the car shows they've got huge 12 VDC power supplies under them plugged into AC current?
Old Mar 6, 2007 | 08:57 AM
james840a's Avatar
james840a
Thanks for the posts guys.
The new battery is doing great so far. Before my stock battery and alt. have been handling the my audio system nicely. Its more closer to 1300 watts max. My sub is the one that is using the most power with a alpine 1005 amp. I have one 4ch amp and planing to add another 2ch in the future to run my front stage tweeters.
Old Mar 6, 2007 | 10:44 AM
350zspl's Avatar
350zspl
at the moment
i am running a stinger 1000 red dry cell in place of my factory under hood battery
factory alt
and ruffly 3500 watts
no light flicker
volt meter on dash remains at 14 volts
even at idle with ac and lights
Old Mar 6, 2007 | 07:12 PM
Z1truth's Avatar
Z1truth
Originally Posted by 350zspl
at the moment
factory alt
no light flicker
Guess what bro, the Stinger battery is a rebadged Hawker Odysessy battery, plus overpriced. Sorry!
Old Mar 6, 2007 | 07:16 PM
Z1truth's Avatar
Z1truth
I also have a Ohio Generator 140 amp alt to help wit dem lights.
Old Mar 7, 2007 | 06:30 AM
james840a's Avatar
james840a
So far i havent had any problems with dem head lights or flickering when running my audio system while driving. Knock on wood.
Z1truth, how much was the Alt you got? did you install it or someone else? Just asking for future info, in case something ever did happen to my alt. Thanks
Old Mar 7, 2007 | 10:34 AM
350zspl's Avatar
350zspl
i pay dist cost
maybe overpriced retail but was cheap for me
not sorry though!!!!!!
Old Mar 7, 2007 | 10:35 AM
350zspl's Avatar
350zspl
factory alt 110 amps
i just ordered a wrangler 180 amp
Old Mar 8, 2007 | 03:59 AM
Larold's Avatar
Larold
Were you using the Yellow or Red Top batteries? I had a red top battery and it died on me in just under a year. When I bought it, it didnt have a book with it. When I traded it in under warranty, the new one had a book. I looked into it, and apparently the Red Top batteries suck for car audio, and they even go so far as to tell you that using it in a car with an aftermarket car audio system will void the warranty on the battery.
