HELP...which speakers to get?
I really need help in buying speakers before i get them. I want to know what you guys installed on you car and if it gave any trouble with the stock mounter. I want to know which models you guys used for front and rear speakers. help me out
Infinity Kappa 62.5I for all four corners. Disconnect the stock tweeter. Rears slip right in....fronts needs a spacer to clear the windows. A lot of people tear apart the factory door speaker and use it as the spacer.
Speakers are a matter of perference. Listen to a number of speakers and pick the ones you like. When you select them make sure you can exchange them if you do not like how they sound in the car. You cannot know for sure until you try them in the car. Speakers will sound different in the showroom and the car because of the different acoustical environment.
bcoffee20
Nov 19, 2015 06:39 PM
