12" W7 under strut bar
Old Nov 2, 2007 | 10:20 AM
04lemansZ's Avatar
04lemansZ
Default 12" W7 under strut bar
Is it possible to fit a 12" W7 under the strut bar in the rear. if so does anybody have pics of it. thanks
Old Nov 2, 2007 | 10:37 AM
dragone2717's Avatar
dragone2717
That might have to be custom.... Try NAZAR in the classifields.
Old Nov 2, 2007 | 10:39 AM
350zspl's Avatar
350zspl
why do you feel it won't fit
Old Nov 2, 2007 | 10:41 AM
Pokémon's Avatar
Pokémon
Havn't seen it.
Old Nov 2, 2007 | 10:45 AM
dragone2717
The air space that sub needs. Putting it in a box under the strut will not give it the proper air space it needs unless you make thing out of fiber glass. Or lose the spare and bury it.... Thats my plan for the 13w7 I wanna put in. 10w7 doesn't cut it for me anymore.
Old Nov 2, 2007 | 11:03 AM
350zspl's Avatar
350zspl
how much air space sealed does the W7 12" need
how much air space does the understrut for the single 12" provide ?
Old Nov 2, 2007 | 11:05 AM
04lemansZ's Avatar
04lemansZ
i dont want to get rid of the spare in case i have a flat. i just found a killer deal on a 12" W7 and wondered if it would fit under the strut bar.
Old Nov 2, 2007 | 11:11 AM
CRIDDA's Avatar
CRIDDA
Its possible with fiberglass, check these guys out. Tell them that Walter's(eclipse on there page) friend Chris refered you, they do good work.
www.AudioTrixOnline.com
They are off sandy plains.
Old Nov 2, 2007 | 11:56 AM
350zspl's Avatar
350zspl
you asking the same ?
i have responded trying to help you
if your not gonna read my response and answer than i can;t help
Old Nov 2, 2007 | 12:00 PM
CRIDDA's Avatar
CRIDDA
Ill answer for him. It needs 1.375 cu. ft. / 38.94 liters
Old Nov 2, 2007 | 12:04 PM
doug's Avatar
doug
i don't think its much a problem of air space.. its that the 12" doesn't fit under the strut bar with a box.. the diameter is too large.. thats why most 12 under the strut boxes i have seen have the sub opening sticking outside of the strut bar opening..
Old Nov 2, 2007 | 12:10 PM
04lemansZ's Avatar
04lemansZ
thats exactly the problem.
Old Nov 2, 2007 | 12:12 PM
CRIDDA's Avatar
CRIDDA
It should fit between the seats and the bar at an angle or even rear facing like doug posted below, I havent tried, but know almost anything is possible with fiberglass. Once again go to the link I put up and see if they would do something for you and they are local.
Old Nov 2, 2007 | 12:18 PM
doug's Avatar
doug
if you wanted a single 12 .. you would have to have it built something like this
thats from http://www.tccustomz.com i'm sure if you talk to them they could build you a single 12 sticking out like that
Old Nov 2, 2007 | 12:26 PM
350zspl's Avatar
350zspl
i guess i am confused
what i am gathering is the poster wants a
1 each 12" w7
1 each under strut bar
if the sub needs 1.375 for 1 each 12" sealed
i next need to know how much space the single 12" under strut bar provides
so i can see the difference that needs to be made up
Old Nov 5, 2007 | 05:15 AM
dragone2717
1 each 12" w7
Really the best thing to do is go to a shop that does custom work and tell them what you want to do.... Anything is possible and if they tell you they can't, Then they are lying. Go somewhere else and get it done.
Old Nov 5, 2007 | 05:23 AM
04lemansZ's Avatar
04lemansZ
thanks for all the inputs
Old Nov 5, 2007 | 09:08 AM
350zspl's Avatar
350zspl
get the Rd Audio Classic
works sealed very well
in that space of the single 12" understrut box
get a RD 1000.1 to push it
and you be banging so hard, so clean , so low
and again for less $ than a w7 & jl amp
i got the RD hook up
Old Nov 5, 2007 | 09:35 AM
Driven1's Avatar
Driven1
Professional
A W7 12" will require a custom box for the location you're requesting. Not only that but if you're putting a W7 in there it needs to be very well reinforced (especially if it's fiberglass). I have 1 12" Kicker which I like alot. Here's a horrible pic (sorry it's the only one's I have right now in my office) of my box that I built with 2 TV's one on each side of the sub.
Attached Thumbnails 12" W7 under strut bar-hin_dc_04_21_010.jpg   12" W7 under strut bar-ztrunk.jpg
Old Nov 5, 2007 | 10:55 AM
350zspl's Avatar
350zspl
it aint possible to build a ported box to spec that will fit under bar
you trying to squeeze 10 pounds of **** in a 5 pound bag
